Question about HP Pavilion dv1000 Notebook
Power issues on HP DV1000
Hi
I have a HP DV1000 laptop computer with the following problem:
The laptop works fine when both power supply and battery are connected, or even power supply with no battery. It wont work tho with just battery.
When the battery is connected alone the machine powers up to post and then dies / goes off within seconds. I have tried a new working battery and get the same issue again.
When it is on via power supply i have used HP tools to test the battery and this shows it as working and charging which leads me to believe that the connections between the battery and motherboard are fine.
I've tried to release static in the notebook and can only think of a motherboard issue but have been told that a new motherboard was tested and had the same results.
Any help appreciated.
  • HP Master
  • 32,281 Answers
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Posted on Dec 03, 2008
HP Pavilion Laptop -- massive power problems?
hello chad
Seem to be circuit issue.
You can check charger with volt meter to check its working ok.
Drain all resistors of power by removing battery and charger and holding down power button for 10 seconds.
There is a power button board that can be bad.
I like to break things down by just powering the laptop with memory and keyboard, power button board only. this will require removing motherboard power button board so it will only be the parts to POST.
Minimal Post .
It can be an array of things from the systems casing shorting it out to other hardware.
Jan 04, 2014 | HP Pavilion dv1000 Notebook
I periodically can't get my computer to start running.
this occurs mostly due to static charges. perform the following:
1. Turn off the PC and disconnect the power supply.
2. Remove the battery from the notebook.
3. Press and hold the power button for 45 seconds.
This will discharge the static charges from the pc. Now check for the issue.
May 24, 2010 | HP Pavilion dv1000 Notebook
My Dell dv1000 has completely died
You are listing this unit as a HP and stating it is a dell.???
Nov 06, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 blank screen
It may not even be caused by the graphics display driver at all. Your Hard Drive may hae BAD SECTORS and the computer is battling to read the system area of the hard drive... Make alse sure that the hard drive commections are fine
Jul 08, 2009 | HP Pavilion dv1000 Notebook
Power supply Problem
hi,
Might be the issue with display panel cable as well so please first try to refix it.
May 29, 2009 | HP Pavilion dv1000 Notebook
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
Wireless Connectivity lost after installation of StartRight application software
Just a question .... Did it connect ok before you installed this new software?
If the answer is yes, uninstall the software, if still not connecting after that, restore your computer to before that software was installed.
Let me know if this helps, if not, please, write back so we can go from there.
Jul 22, 2008 | HP Pavilion dv1000 Notebook
Weird power issue
Have you tried removing the battery and then turning the laptop on? If this works then you have a battery issue rather than a battery terminal problem (which is the only other issue I can  think of that would survive a BIOS reset.
Jul 05, 2008 | HP Pavilion dv1000 Notebook
No power and there is a clicking noise in ac power adapter
hearing a clicking sound inside an ac adapter is something very unusual. it could be possible that this is a factory defect. call hp and ask for a replacement of another brand.
Jun 17, 2008 | HP Pavilion dv1000 Notebook
HP Pavillion power link blinks
aa505 -
I can almost guarantee you this is an issue with the power jack on the laptop's motherboard. Even though it may not appear to be loose, its most likely the solder connection on the motherboard has broken, only allowing intermittent connection when the laptop is in /just/ the right position.
It'd be best to get this looked at sooner rather than later, preferrably if the computer is still under warranty. The connection will steadily decline, until the laptop is unusable.
Otherwise, let me know if you want to get rid of the system! I have a system, almost exactly the same model, that I need parts for!
Hope this helps!
-thinstatic
Jun 12, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
227 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
