Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Shaky distorted picture first 5 minutes when tv turned on.
I have a 52 in. Mitsubishi big screen about 7 years old. not hd. Recently, it has begun having a distorted shaky picture for the first few minutes after I turn it on. Something's going out I'm afraid. worth trying to get fixed or should i go with new tv?
  • rand250 Dec 06, 2008
    Thanks, Chrisry696!
    Scholar:
  • 38 Answers
Those have a problem with the capacitors going bad in power supply. Yes, it's worth having checked out because a GOOD shop will be able to fix the problem and not have to change a board. Very common problem with these sets. Mine did the same thing until I fixed it. Just do your homework when finding a shop. Call around and talk to other people in the area to see who they use etc.. Good luck. Could be a very simple repair. Have it checked.
Posted on Dec 05, 2008
Timer light will not stop flashing. can't turn on TV
Unfortunately the first generation DLP's from Mitsubishi are prone to have Capacitor failure through out the chassis. Most likely that is what your set is experiencing. I would start by replaceing the suspect caps on the DM amd The Power boards. You can get the V26 Chassis DM/Power repair kit from www.tvrepairworld.com which also contains instructions.
Jun 21, 2010 | Mitsubishi WD-52725 52". Rear Projection...
The problem is a shaky picture with a static line that's vertical when watching regular TV. This problem does not happen when not watching in HD through our Myth TV (DVR). Closed captioning does not...
Regular TV, you mean by the aerial and internal tuner, if it is like that, then it is a problem with the TV tuner board.
If by regular TV you mean an external TV box, then the TV box is faulty or you have a cable or ferquency problem.
Sep 13, 2008 | Televison & Video
3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Dec 28, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
52 inch RCA Home theater-Sound is distorted/scratchy
I unplugged the tv for 5 minutes. When I turned it back on, I had sound!
Aug 01, 2009 | RCA 32V420T 32" TV
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture dimming and an ominous clicking sound
If this set is really only 5 weeks old, place a warranty service request for repair. This should not be happening. Either the ballast is bad or the lamp. In any case, either should be covered under warranty.
Please keep us updated.
Thanks,
Dan
Feb 13, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Sony 52" rear projection tc
Hi, thats the code for AKB fault, this requires a tv tech to fix,, not a big bucks repair, video-tek
Feb 09, 2009 | Sony KP-43T90 43" Rear Projection...
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
60" Mitsubishi TV - Approximately 6 years old
Good Day;
Try resetting the TV and any BOX by unplugging both for @ to 5 minutes then plug back in.
Good Luck, big IRISH.
Aug 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
233 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
