Vizio GV47L FHDTV10A
I have a 47 inch vizio lcd. model is the GV47L FHDTV10A.
i can turn the tv on. after about 20 minutes the tv will start to dim and flicker, and it will go totally black. it is making a popping sound as well. i can turn it off and then turn it back on and i will stay on for about half as long. (may be getting hot)
i changed both master and slave backlight inverter boards. it now just shuts off automatically. i kept turning it back on and after about 30 minutes it started to do the dim and flicker and popping thing again.
wondering what i need to do.
  • Anonymous Dec 26, 2008
    vizio 47 lcd has no power
  • 58 Answers
Sounds like a lamp failure.
Posted on Dec 06, 2008
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
I have a Vizio TV and would like to add a Chromecast streaming media player,the information I have shows the player powered via the USB IN 1 port,would the RGB PC port work? I have model #GV47L FHDTV
Chromecase is a USB 'stick' type device with a USB interface. The RGB port is a video only port on the TV and not compatible with USB signal levels or the physical plug type.
Jan 05, 2015 | Vizio GV47LF Television
Vizio VO47L FHDTV10A black screen no light
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Vizio VO47L 47 in. LCD TV
Vizio gv47l
The problem is with your IP (inverter / power) board. This is a pretty common issue, actually... one I see almost daily. The power board for your TV is part number 0500-0507-0260, but they're not available anymore... the sub part is 0500-0507-0260R.
Jan 17, 2014 | Televison & Video
I'm have a vizio TV model gv47l fhdtv10a,I need
call any tv place they have new installation kits thatyou can buy
May 17, 2013 | Televison & Video
Fuse location's on vizio VO47L FHDTV10A
the inverter has failed which is a very commom problem. You can get the replacement inverter from www.tvcircuitboards.com
Jun 03, 2012 | Vizio VO47L 47 in. LCD TV
VIZIO GALLEVIA modle VIZIO GV47L FHDTV10A
Most plasma TV's have secoundary power boards, witch can be the cause, now I would try if I where you is to unplug it and let it set a hour or two, if that did not work then the tv will need to be looked at locally. The cause can be a bad power board inside the TV witch is a major cause why a Tv would have a power light put no function at all.
Hope this helps if you have any questions as to what parts to buy www.partstore.com is a best resource.
Oct 18, 2011 | LG 42PG20 42 in. Plasma HDTV
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
1,575 people viewed this question
Top Televison & Video Experts
