Question about Kenwood Excelon DDX-7015 Car DVD Player
I have an issue.. my battery died yesterday the guy who jumped my car messed up and attached the jumper cables wrong on his battery. Now my kenwood excelon ddx 7015 wont turn on at all do you think it is fried?
  • 37 Answers
Hello Melissa,
The first thing I would check is if your fuse is okay. If your fuse is blown replace and try to turn on the radio. If the fuse is good have the radio taken out and have it bench tested. take the power wire and the memory wire put them together and apply power to them then take the black wire and connect it to ground if the radio turns on then its okay and he fried something else. If the radio doesn't turn on then chances are that he fried it.
You can use a car battery to test your radio or a portable boost jumper.
Hope this helps you.
Posted on Dec 04, 2008
2005 nissan murano jump started witnow it will only idle but will not accelerateh jumper cables reversed
NOT SURE WHAT YOU SAYING ? WHEN GETTING JUMP STARTED, THE BATTERY FROM THE GOOD VEHICLE MUST PLACE JUMPER CABLES ON BATTERY TERMINALS, THE CAR BEING JUMPED, YOURS, THE (+) TERMINAL IS JUMPED FROM GOOD BATTERY, THEN THE (-) JUMPER CABLE FROM GOOD BATTERY GETS CLAMPED TO YOUR CARS FRAME OR ENGINE BLOCK, NOT YOUR DEAD BATERY !!!!!!! YOU MAY HAVE SHORTED SOMETHING OUT, MAYBE EVEN YOUR COMPUTER CHIP IN THE ECM ! YOU NEED A MASTER TECH TO HELP YOU ON THIS ONE, I WOULD'NT TOUCH THIS WITH A TEN FOOT POLE ! SORRY, I COULD BE WRONG, BUT, NOT AN EASY ISSUE OVER THE NET !!!!!!
Mar 26, 2013 | 2005 Nissan Murano
Tip
How to jump start a vehicle safely
You have a dead battery and need a jump start. There is the right way and the wrong way to accomplish a jump start safely. Because of the potentially severe hazards due to improper use of jumper cables it must be done correctly. Auto batteries contain Sulphuric Acid which can blind you, or at the very least burn your skin. Also auto batteries vent off Hydrogen Gas which is highly explosive even from the slightest spark. Because of this danger it is critical to attach the jumper cables in a precise sequence. 1. Park the vehicle with the GOOD battery close to the vehicle with the BAD battery but do not let the vehicle touch each other. Make sure the cables are not routed so as to touch any moving parts, such as a fan blade. 2. Attach the jumper cable Positive + terminal to the GOOD battery Positive + terminal. 3. Attach the other end of the jumper cable Positive + terminal to the BAD battery Positive + terminal. 4. Attach the Negative - jumper cable terminal to the GOOD battery Negative - terminal. 5. Attach the last jumper cable Negative - terminal to a heavy metal ground part of the engine and NOT to the dead battery Negative - terminal. Reason being this last connection will cause a spark, and you do not want a spark next to the battery where it could ignite the Hydrogen. 6. If the engine of the donor vehicle with the good battery was not left running, start the engine and let it run for 2-3 minutes to put a charge in the bad battery. 7. Start the vehicle with the BAD battery and then remove the jumper cables from the batteries in the exact opposite order you installed them.
on Jun 19, 2010 | Honda Accord Cars & Trucks
Xterra won't start when the battery has juice free of corrosion and starter is freshly installed
Check the cleanliness and tightness of the battery terminals. Loosen, twist and retighten them. Also check the cleanliness and tightness of the black earth cable where it attaches to the engine block/bodywork. A bad earth can cause the symptoms you describe.
A quick check you can do is to connect a jump cable to the battery negative terminal - the earth - and connect the other end of the cable to somewhere suitable on the engine/bodywork.
If the car starts no problem with the jumper cable - it's pointing towards a bad earth/connection somewhere on the battery earth
Mar 14, 2017 | 2001 Nissan Xterra
2003 Elantra-Car ran fine until my son's door was not complelety shut and battery died, jumped car, but once the jumper cables were removed the car dies. Thinking it was an electrical issue, check
some alternators need battery voltage to stay running and after killing a battery if may not recover and you will need to replace it then i would check the fuses its posible that when first jumped the cable where on backwards
Aug 07, 2012 | Hyundai Motor 2003 Elantra
I have been jumping my craftsman riding mower off for a while and its always worked. now as i take one of the jumper cables off ,the mower dies everytime.could you tell me whats wrong.
Sounds like one of the battery cables are bad or loose . Start by removing the black cable from the battery. clean the inside of the connector with emery cloth or course sand papper. do the same for the battery post. Remove the red cable and do the same. Attach the black cable to the - neg. post on the battery. attach thr red cable to the + pos. post on the battery. Now follow the black cable andand make sure it is connected to the engine block or somtning metal. remove it and clean the connection point. Also it would not be abad idea to have the battery load tested. It could be that it is so bad that it will not produce enough voltage/amperage. How old is the battery?? Are you jumping it with another battery or a charger /starter?? If charger /starter try a battery. szm230
Apr 15, 2011 | Craftsman Garden
How do I give a jump start to another veichle?
Your jumper cables are most likely red and black. Locate the positive and negative terminals on your battery, they are marked ( + ) or pos.,that's the red one, and ( - ) or neg. that's the black one. Conect one end of your cables to your battery (doesn't matter which one you do first) make sure you are connecting the other end to the same terminal on the dead battery (that is to say positive to possitive) now do the same with the other cable. There may be a little bit of a spark that's normal when you make the final connection. The danger is in taking them off, do it in the same order that you put them on, if you take both cables off at the dead battery and they touch you are going to be having a bad hair day. the thing that most people don't get is you have to have a good clean convention. If you don't try wiggling the clamp on both batteries to make them dig into the terminals. Also there is a huge difference between someone who left the lights on in parking lot and someone with a dead battery on the side of the interstate. The guy in the parking lot has a dead battery, the guy on the side of the road has a dead battery and a dead alternator, he needs a tow truck, not a jump.
Jan 25, 2011 | 2006 GMC Canyon
How do I jump the battery?
Hook up the red cable wire to the positive terminal on the battery of the car to be jumped, then hook up the other red jumper cable wire to the jumper vehicles red or positive terminal, it is recomended on the car to be jumped that you attach the negative cable to a metal bracket on the motor or body that can be attached securely (good connection), then attach the other last cable to the negative battery terminal, if you cannot find a suitable bracket to attache the negative cable to use the negative battery terminal. When doing all this try to keep the two ends of the cables seperated from each other, always wear safety glasses when working on auto batteries the can explode if a spark or flame gets too close to the top of the battery.
Jul 15, 2009 | 2003 Chevrolet Venture Passanger
Car died at light. battery light on. got a jump start car cranks as long as cables hooked up. take cables off car dies. will not stay started.
Thatttttt's alternatorrrrr.
Your alternator charges your battery. No alternator, no battery charge.
Apr 23, 2009 | 1998 GMC Jimmy
Car just died after putting new starter
When you put the new starter in, you didn't put one of the cables back on the post. It probably grounded itself enough to start and run, then moved by vibration, or a pothole, or gravity, and killed the motor. As for the arcing battery.... are you sure you didn't attach the jumper cables to the wrong posts?
Jan 05, 2009 | 1997 Nissan Pickup
Kenwood Excelon DDX-7015 Car DVD Player Logo
183 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
