Question about Philips Magnavox 51MP392H Rear Projection Television
NO PICTURE OR SOUND
I PICKED UP A 55 IN. MAGNOVOX 51MP392H-17 FOR FREE TODAY. THE GUY TOLDME IT ONLY NEEDS A FUSE. THE POWER BUTTON ILLUMINATES RED WHEN HIT BUTNO SOUND OR PICTURE. I LOCATED 1 FUSE BY THE POWER CORD WHEN I PULLEDIT THE POWER BUTTON DID NOT ILLUMINATE ANYMORE. THEN I LOCATED ANOTHERFUSE ABOUT CENTER RIGHT I PULLED IT AND PUT IT IN THE FIRST FUSE SLOT IFOUND AND THE POWER BUTTON ILLUMINATED AGAIN BUT STILL NO PICTURE ORSOUND, DO YOU THINK IT IS STILL A FUSE? IS THERE ANOTHER FUSE THAT I AMNOT SEEING
    Genius:
  • 1,139 Answers
Hello mtf420ak,
I do not believe this is a problem with a fuse since by your experiment both fuses are good. Now put the fuse back in and if there is still no picture and no sound we can assume that the problem might be some other component on the power supply board, and or the High voltage section because this sounds like a shutdown circuit problem. If it is a shut down circuit problem the section that might be malfunctioning would be the High voltage section of the TV. I would suggest that you let a qualified TV technician troubleshoot and repair this television. I say this because this is not a simple problem, this is an issue that requires a knowledge of electronics and TV repair.
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 04, 2008
51mp392h/17
If you do not have menu, problem in power supply, supplying the 130v to the high voltage circuit. Check all pico fuses in power supply.
Nov 16, 2011 | Philips Magnavox 51MP392H Rear Projection...
No Sound, No Picture on Magnavox 51MP392H/17
If you hear a constant clicking or chirping sound get the chirping TV repair kit from www.TvRepairKits.com
If you have no video - but have audio - its most likey the HVG.
Note: When the video goes out sometimes its hard to tell if you have audio becuase you can't see the screen to change to the correct channel.
May 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox 9p6034c103
sounds like somthing may have gotten knoked loose in transportation. I'd check all the interneal connections, make sure its unpluged for a few hrs or a day before sticking unexperienced hands in there. there are some high voltage capcators in it. stay away from fat red wires the size of TV cable.
also call the people you got it from make sure they know your not holding them responsible and ask if they fixed anything recently or in the past espically the IC convergence chip and resisitors, usally those go on these sets.
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics
http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Good Luck!
Oct 04, 2008 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnavox 51" Projector TV. Model 51MP392H/17
Hello bullmuscle,
This is a power supply problem, I would suspect the HV power supply because the primary and secondary supplies anymore are tied to the HV power supply. This type of repair requires certain pieces of equipment, to test voltages, look at signals, and to if need be test for shorts in inductors (Switching PS transformer and Flyback transformer). I would not recommend that you try to fix this yourself, The cost for this type of problem is not that expensive and can be done in one evening, if the parts are available. You may be fortunate and it could be just a blown fuse, in the HV or LV power supply circuit
I hope this helps,
Thank you,
Shuttle83
Jul 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox rear projection
If the red converge will not line up, then there the convergence chips are actually bad - the repair will cost around $700 if you go through a Magnavox authorized service center. I would look at posts by Slinteriors in the Philips or Magnavox rear projection sections - he has some ideas on generic chips that might be had for cheaper.
Jul 06, 2008 | Toshiba 55H70 55" Rear Projection...
Magnavox model#51MP392H/17
How much is the conversion box on a foor model magnovox televisiion..
Dec 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
No power
Brand, and size please? Most problems come from either the power supply, or deflection circuits.
May 22, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
