Casio fx-300ES Calculator
Problem for Casio fx-300ES Calculator
How to convert log
By naomiobasa on Dec 03, 2008
How do i convert learning curve firgure of -0.3219(log 0.8/log 2) to number by multplying it to 2500.
Solution #1
posted on Nov 01, 2009
Not Rated)
k24674
Rank: Guru  Casio Office Equipment  Expert
Rating: 87%, 676 votes
Hello, The first remark is this. The ratio log(0.8)/log(2) is by definition binary log of 0.8 ( meanibg log in base 2 of 0.8) The second remark is good news for you.: When in MathIO, [SHIFT][MODE][1:MathI0], your calculator can compute directly the log in any base of any number. To use the functionality, you press the key below [ON]. It is a log symbols with a small solid square, and and erect empty rectangle.
When you press the key the screen shos a template. In the smaller and lowered square goes the base (here 2). When you enter the base, press the right arrow to move cursor to the rectangle inside the parentheses and type in 0.8. Use the right arrow to move the cursor out of the parentheses.
Practice: try that. the result should be -0.321928095. Good. Now use the replay button to move cursor to the command line outside the right parenthesis. I am going to give you the other key stokes. Let log(2,0.8) be my representation for log in base2 of 0.8. Then you enter the rest of the calculation as
log(2, 0.8) [*] [ ( ] [(-)] 0.321 [ ) ] [*] 2500 [=]
Here [*] is the multiplication sign [(-)] is the negation (change sign), just above the [RCL] key.
[ ( ] is the left parenthesis and [ ) ] its matching right parenthesis. Both of them enclose the number -0.321. It underlined them for clarity.
The result should be 259.0716344
If you do not like what I did above, you can always do things the old way. You use the log key just above the [COS] key. In that case -0.3219*[LOG] (0.80)/[LOG] 2 * 2500. Do not to supply the ) for both log. The calculator inserts the left ones by default.
Hope it helps.
Comments:
Nov 02, 2009
- Sorry. In the antepenultimate line it should read: Do supply the ) for both
Nov 03, 2009
- Here is a picture of the log template I was referring to (2nd line). Compare the first and second results. You calculation is on third line. The - sign is the change sign represented on your calculator as (-).
Was this helpful?
Yes
No
Popular Solutions for Casio fx-300ES Calculator
Questions and Unsolved Problems for Casio fx-300ES Calculator
Do you recommend Casio fx-300ES Calculator?
Answer
Answer
What battery to I buy for the backup battery in fx-300es?
Answer
whats the code of creating calculator in visual
Answer
Can you set the present value of a discount bond?
Answer
how do i change the exchange rate on my casio hs-85te tax & exchange calculator?
Answer
our teacher told us to make a scientific calculator using visual basic without disccussing on how to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Casio fx-300ES Calculator:
Top Calculator Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Calculator Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
