Question about GE JES1142SJ Microwave Oven
Display fully lit (all characters) @ plug in but unit not running
I bought this unit 2nd hand, although it does not appear to have been used. (Perhaps this is why).
As I plugged in the unit, the full display lit up, showing all characters (resembling 8,8,8,8,), but will not accept any commands on the touchpad. I tried plugging and unplugging, looking for a reset, etc., but found nothing at first glance.
Can anyone please help me?
  • inactionfigu Dec 08, 2008
    Thanks for the insight. I still have one day left that I can return it for store credit, at least! Good timing, and thanks again!
  • GE Master
  • 9,098 Answers
I'd say you have a bad keypad, or possibly a problem on the control board.
But with the cost of a comparable unit ($85 at Wal-Mart), it may not be economical to repair.
It would run $39.95 if we just repair the board, or about $50 if you replace the keypad frame assembly yourself.
Spending a little more would get you a new oven with a warranty.
Posted on Dec 08, 2008
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
The microwave runs but does not heat the food. Unit was bought sometime in 2004 or 2005. (When I press the MICRO control pad, a number 16 with underscore colored red appears near the upper left hand of...
Whirlpool typically supplies a service sheet with schematics for servicing the oven. This is normally located in the compartment where the micro control board is and requires you to removes it to acess it. These service sheets have fault codes and causes on them.
If you are inexperienced at working with electronics I suggest replacing the unit as the cost to have the unit serviced will likely exceed the cost of a new unit.
Good Luck
Sep 07, 2010 | Whirlpool MH7140XF Microwave Oven
My KHHS179LSS-3 will not let you control microwave from touch screen un pluged unit plug back in touch error high fail low fail appears on screen
I was afraid I needed to replace the microcomputer when my KHHS179L touchpad was unresponsive. I was able to use the ADD A MINUTE feature, so I knew the unit worked. There had been a power outage of less than a minute to my home recently (I was unaware of this until I asked the kids if they had done anything to the microwave). I popped around on fixya.com and really didn't find an easy solution-my favorites. I loaded kitchenaid.com and found the answer in the FAQ's. Although the control lock out icon was NOT LIT-apparently, that power surge locked my controls. By holding the stop button for 5 seconds once and then aagain a second time, miraculously, my touchpad was restored> HOORAY!
Jul 10, 2009 | KitchenAid KHHS179L Convection/Microwave...
Display not lit up
Seems like the display panel went bad. You can check for sure by unplagging the unit for 45 seconds and plugging it back in. If still no display order a new display panel.
Please rate if you are satisfied
Feb 12, 2009 | Microwave Ovens
Total power loss during use
Check the voltage on the outlet,make sure it is 115v -- 122volts max, any less will cause it shut off, make sure the polarity off the outlet is correct and it is grounded,check all of your wiring connections, if all this is ok replace unit with a different unit or different supplier of unit
Jan 26, 2009 | Microwave Ovens
Microwave not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, your controller or keypad may have moisture on it.
Sep 08, 2008 | Panasonic Microwave Ovens
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
Sharp R-1611 panel display, lights & touch pad not working
This is a problem with the control panel assembly, which we repair nationwide for $39.95. You can find full details on our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 11, 2007 | Sharp R-1610 Microwave Oven
GE JES1142SJ Microwave Oven Logo
137 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
