Question about Akai PDP4225M 42 in. Plasma Television
My remote for my akai pdp42z5ta stopped working
My remote stopped working and i lost the manual .i cant seem to even find this model tv on this site even though its less than a year old . The model # is PDP42Z5TA and the remote model is KC02-D2 please let me know if you can help me . Thank you Travis Pardue
  • travispardue Dec 03, 2008
    figured out myself
  • swren31 Mar 16, 2009
    Remote stopped working. Check the spring where the batteries go. On mine, the spring gets compressed and the positive end doesn't touch. Gently pull on the spring to stretch it. You'll probebly have to do this on occasion, or get a new remote.
    Problem Solver:
  • 8 Answers
Yes, I can help you either fix the original or get you a brand new one. By the way, did you change the batteries. I know you did, but this procedure is the first step. If you change the batteries and the remote doesn't work, the problem can be inside the remote, specially if it happen to be dropped. Or the sensor in front the tv may be bad if does not respond to the remote. The best way to check the remote control is with infrared checker, an special equipment I have at the shop. I can ckeck it with that for you and fix it as well. Please e-mail me at
Posted on Jan 22, 2009
Akai PDP42Z5TA turns on but dark screen, no sound, keypad/remote cannot change and cannot turn off. Whats wrong?
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 13, 2014 | Akai PDP42Z5TA 42 in. Plasma Television
My tv remote doesnt work?
Make sure Batteries are good. Even if they are new they still can be drained and bad. Make sure they are in the right way. make sure the connectors inside the remote are not dirty. Clen them with A very fine sand paper.
Dec 31, 2010 | Akai PDP42Z5TA 42 in. Plasma Television
AKAI Menu screen wont stop flashing over tv signal
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
May 11, 2017 | Akai PDP42Z5TA 42 in. Plasma Television
Remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
Nov 22, 2008 | Akai LCT3215/26 32 in. LCD Television
Remote won't work
Is it a multi-device remote at all?
This set is probably a rebranded Samsung so you might try their codes or check Samsung's website for a code listing for that model.
Sep 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
i have nec 42" lcd tv have lost remote and cant do anything as child lock is on can only turn of at mains can anyone please help to unlock?
Jul 04, 2008 | LG 42LC2D 42 in. LCD HDTV
Screen will not appear
You have just found out why the plasma sets are fading from the market.
Both of you may have a power supply problem. The PS in plasma TVs is more complex than in LCD sets and therefore more likely to fail.
Since Akai is so poor on product support, they may not even have parts since that set was made by Samsung who also doesn't want to hear anything about them (their site doesn't recognize the Akai model number), you may be out of luck.
In researching Akai, I find large number of folks who will not buy any Akai anythings again.
This kind of performance is unusual for a Japanese company.
Jul 04, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
No picture or sound
what do you have connected? you can try withe basics. if you can try a rg-6 cable into the f connector. then try a dvd on video 1 and change the input to input 1 and see. if nothing else try a hard reboot
thats unpluging the tv for about 2 min. then reconnect.
Apr 08, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
Jan 06, 2008 | Televison & Video
Akai PDP4225M 42 in. Plasma Television Logo
350 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
