Question about Dayton Heating & Cooling
I have a Dayton 4LX55 tubular heater in my shop that won't light
The fan runs fine but the burners never light.
    Problem Solver:
  • 15 Answers
Check your thermostat and see that it’s wired correctly, it should be as followed for this particular unit; R-W-G from the thermostat terminal, and R-W1-G on the units terminal strip. Also check and make sure you have gas to the unit and make sure the switch to the gas valve is in the “ON” position. If all of the above is correct and working, you could have a bad igniter, or a have a flame rollout, or high limit switch tripped.
Hope this helps
Posted on Dec 03, 2008
I have a hanging Dayton in garage pilot lights fine furnace fires up runs 6or7 min. then burner and pilot go out
Does unit fan come on ??? Is flue clear as most units have a safety klixon if exhaust not venting properly.
Nov 24, 2012 | Dayton Gas Furnace Heater
Dayton 3e226e fan runs but burner will not light
Hello, since the inducer motor is running this can be either a bad ignitor or a pressure switch problem. Jump the pressure switch to see is the furnace will run, if it does there is a problem such as clogged vnt pipe, tubing clogged from switch to inducer motor, or the switch itself is bad. If it does not run most likely a bad ignitor
Nov 13, 2011 | Dayton Heating & Cooling
Have a dayton 3e240e heater and the fan does not work, pilot light works and main burner work as well. no fan.
Had a similar problem where the fan wouldn't turn on but everything else worked. If you can verify that your fan isn't kaput, it's most likely the "Fan Time Delay Switch."
After a few hours of searching, you can find them on Grainger. This should be the one for your heater: http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1vld6&op=search&Ntt=1vld6&N=0&sst=subset&typeaheadSearch.x=23&typeaheadSearch.y=3
It's located in a electrical box behind the heater under the relay (at least it was on mine). Hope this helps!
Feb 06, 2011 | Dayton (3E379) Heater
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
Why does a pilot light go out,but the fan keeps running?
some heaters use a timer to bring fan on as opposed to some which use temp
Feb 24, 2009 | Dayton (4LX41) Heater
Dayton gas furnace
try cleaning the flame sensor and the burner , check out the pressure switch might be blocked in the tubes
Dec 07, 2008 | Dayton Gas Furnace Heater
I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Nov 20, 2008 | Dayton (3E379) Heater
Dayton 3E227A Heating Cycle
The sensor for the thermostat is probably going bad or has bad connections. It is (or thinks it is) heating up fast and therefore shuts of the heater.
Dec 30, 2007 | Dayton (3E386) Heater
Dayton gas heater mod 3E404
This is an easily fixed problem. There are two thermistor switches on Dayton furnaces. One controls the fan motor run function and the heater valve on/off function. The other called a blocked vent switch (located in the top front of the heater) stops the gas valve from opening in the event the
vent is plugged. However, if the furnace was totally shut down for the summer and is now being fired up for winter, the block vent switch has to be reset. The switch has a reset button on it, push it and it should solve your problem. Also, check to make sure the fan run thermistor is clean and does not have debris around it as that acts a insulator for heat to keep the fan run function on.
Dec 30, 2007 | Heating & Cooling
Heating & Cooling Logo
212 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
