Question about Zenith C27A24T 27" TV
Speakers have died?
Hi. Hope someone can help. I have a Zenith 27" regular tv about 12 - 15 years old probably. Works great until a couple of days ago. A huge screeching noise started while I was watching something. I changed the menu settings to mono speaker (from stereo) and the screeching stopped. Since then, I have got to turn the sound up a little more and there is a slight static white noise. Is this repairable? Or is it worth it? Thanks. K
    President:
  • 1,284 Answers
Probaby the stereo decoder IC went bad or a supply voltage to it is too low or noisy. If it has audio output jacks on the back of the TV, connect it to an external amplifier and see what that sounds like. If it is ok in stereo or mono mode then the amplifier in the TV is bad. This will prove that the stereo decoder is ok.
Posted on Feb 01, 2007
Zenith C27A24T 27" TV -
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears or rolls ( in your case )...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 21, 2011 | Zenith C27A24T 27" TV
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
Picture but no sound
press mute button on tv remote
Oct 20, 2008 | Zenith B27A11Z 27" TV
Zenith 27" TV
I sorry to say I think you have a component failing that is related to heat. 15 years is a long time and if the TV was used in hpot conditions over the years it may well be the proble, or it's just old.
Sep 23, 2008 | Zenith C27A24T 27" TV
Zenith 27 in TV
I am looking for a couple of parts for my zenith tv model # A27A11D.
fuse-1360011423A
knob array-04610578
Apr 25, 2008 | Zenith A27A11D 27" TV
T V sound
great ma ma- first of all if the tv was dropped,then there is a good chance that the pc board was damaged most likely a small crack near the audio section.This sort of repair is probably better left to someone with very good soldering skills. If you think you know someone,let me know I can help. cooltek Feb.15/08
Feb 14, 2008 | Zenith C27A24T 27" TV
Speakers
Tvs are wired differently these days. Your old Zenith for example probably had a selector switch that allowed you to change from internal or external speakers, bandpassing the audio from the internal amplifier to the audio out connectors. Your Sharp on the other hand may be controlled by customer menu to perform the same function as the external switch. Go into the menu and sub-menu of the audio and see if it gives you any choices for selecting internal or external speakers... If it doesn't it probably will not bandpass the already amplified signal, which means if you want to listen to your Tv on those external speakers you'll first have to pass the audio sample through an amplifier.
Hope this helps.
Bill
Nov 14, 2007 | Sharp 25N-M100 25" TV
RGB-PC input problem?
I had the same problem and the fix for me came from updating the driver for my video card which you can get from the manufacturers website
Jun 19, 2007 | LG RU-44SZ51D 44" Rear Projection...
After 20 months old and now dead
I purchased this tv 2/06 and it went POP in 04/07. Less than 60 days after my warranty expired. Went back and forth with Zenith for several months. I refused to take NO for an answer. Customer service stinks and you have to be very persistent. They eventually agreed to fix it. Repairs cost over $2000 and I have my tv back. Next time it breaks just going to throw it out. Zenith sucks.
May 09, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith C27A24T 27" TV Logo
304 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
