Question about Imperial IFS40 Deep Fryer
Thermocupler wire broke
The thermocupler wire broke on my imperial fryer. Can it be spliced or does it have to be replaced? If I can splice it to keep it working until new part arrives.
  • 57 Answers
Yes.. you can splive thermocouple wires. it could be polarity senstive though so get it.
Posted on Dec 03, 2008
My air conditioner thermostat keeps losing power
The power for thermostat come to an from the thermostat with the red and common wire. Check for proper connection to thermostat and check thermostat wire from the thermostat to the air handler. Technicians sometimes do not install splices well and sometimes the splices comes loose. I prefer using rtv loaded wire nuts to make splices when I can find them. Another cause for this problem is bad insulation on thermostat wire allowing wire to short out. If this is your problem, you need to replace the thermostat wire itself. If these do not fix your problem, you may need to replace the thermostat itself.
Hope this helps
Oct 20, 2014 | Heating & Cooling
Splicing kirby electric cord
If you are unsure on how to splice the cord back together it may be best to just purchase a new cord. You can find a new G6 cord and it is easily installed into the switch at the base of the Kirby.
Kirby G6 Power Cord
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 10, 2014 | Kirby Generation 3 Bagged Upright Vacuum
Broke wire connector
First thing you will want to do is check the warranty for your lockset. If they will cover the lock under some part of the warranty then do that, if not. You could try getting a butt splice gauged for the wire and try splicing it together like that but there is no guarantee that it will work. Most electronic locksets have very sensitive wiring in them and even the smallest pinch on the wire can ruin the lockset. Try cutting out the parts that were broken off and splicing them together.
Feb 27, 2013 | Schlage Locks & Locksmithing
Pilot lites but goes out when releasing valve
when the pilot light lights up and goes out when you release the valve its because the thermocupler capillary tube will not open the gas valve its a safety devise and is faulty you will have to replace it the thermocoupler
Nov 24, 2011 | Heating & Cooling
Passenger window goes down but not up
On the passenger side pull carpet back by the kick panel you will see some wires loomed together pull the loom off u will see several wires spliced from the factory those get worn from passenger traffic...
Nov 17, 2011 | 2001 Pontiac Montana
Power door locks and windows dont work, interior lights stay on thinking driver side door is open
CHeck the black wire in between the door and frame. There is a cluster of wires in a rubber boot. Guaranteed that the black wire is broken. Splice it back together.
Feb 20, 2010 | 2004 Jeep Grand Cherokee
Sterling model TF-45, thermostat calls for heat, gas valve opens up, thermocupler starts pilot, unit fires up only to shut down within 30 seconds or so... I had replaced the high limit a while back,...
Sounds like you broke the hot surface ignitor ?? he was on about the flame sensor a rod .so replace what you broke and clean the flame sensor ,also check the pressure switch.
May 08, 2017 | Sterling Heating & Cooling
Want to put a toggle switch for my wipers in my '89 chevy 1 ton van i broke the lever for it
safer to buy and replace with new or one from salvage yard than to splice wires to wiper motor u will get one speed -but can be done splice off power from hot side of fuse to one side of switch disconnect harness and connect of other side of switch to line to w/w test which one is reg speed and splice in
Oct 21, 2009 | 1983 Chevrolet C3500
Imperial IFS40 Deep Fryer Logo
117 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
