Question about Miele WT945 Front Load Washer / Dryer
Doesn't heat up the water, no matter what program chosen
Hi, i've got WT945 and was working happiliy for about 2 years. But all of a sudden, it's not heating up the water at all. whatever programme i chose! realised this problem when i put very few load in, and chose 90deg wash. after 50min or so, the washing was "finished" (or so the beep told me), but the cloths were still dirty, AND cold. wondered why, and tried it once again. this time checked the water temperature after 20min by opening the door, and it was veeeery cold! i've unplugged the machine to reset (hopefully...) everything, cleaned the drainage and the water pipe. there is no error signal. if you know anything that could be done, please help me!! thanks,
  • Anonymous Mar 01, 2008
    Hi we have a WT945 and we are very happy for the service but after almost 6 years amonth ago we encounter problem, the machine didnt drain and the red light with water inlet/drain became on and sound. We try to clean the drainers and empty the water but every wash, we need to empty and use the spin to dry it, please help us, is very important to us the machine thank you.
Hg4wj
Posted on Feb 10, 2008
Problem is usually the Set of relays in bottom of machine supplying power to the heater element, these are accsessible from the front of the machine once the hinged front panel is opened. I speak from personal experience , have had a few of these go on my Machines
    Problem Solver:
  • 13 Answers
Heating element or a thermostat is open cuircit. Regards Appliance Doctor
Posted on Feb 02, 2007
Water will not heat
Reset to Factory condition and purge system.
Apr 17, 2013 | Keurig B70 Coffee Maker
I have a MicroExpress laptop model FL92 that I bought several years ago. Ever since I got it, I've had problems with it suddenly quitting without warning. It appears to be heat-related and has p
depending how computer savey you are, you could open it up . clean heat sink and apply new thermal paste to the processor. not too moch, but not too little
Jan 30, 2013 | Computers & Internet
How to change the heating element on miele wt945
take the back off the heater has 1 10m nut in the middle and 2 wires on it take off wires undo 10m nut prize off the heater it is compressed in a rubber it might take a bit of force the best thing to do before this is to test the heater with a multi meter 1st if there is no reading across the two terminals the heater has gone get a new heater and have a look at it you will see what holds it in
Sep 26, 2012 | Miele WT945 Front Load Washer / Dryer
I have the bissell pro heat turbo microban cleaner. It's about 2 1/2 years old and maybe used 8 times. The brushes do not work and it's not suctioning up the water. I've checked the belt on...
You already said it, so check the carbon brushes. Once it is no longer able to push the rotor or stator it need to be replace. Carbon brushes are customized at the machine shop, so you should bring it so that you have a sample of the brushes itself. Just be observant when disassembling the motor so that you put it back to exact place.
Thanks for asking.
Jul 13, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Keurig B70 has begun dispersing various amounts of water no matter what size cup is chosen
you will need to try the vinegar/water cleaning... 1/2 cup white vinegar to full tank water..run until empty..then redo, with clean tank of water....taste water when done, no bad taste
this has to be done on these machines at least once a year.....
Dec 18, 2010 | Keurig B70 Coffee Maker
Miele WT945 leaks water from internal drain
Hi
If it is the bottom hose on the condenser box leaking.
This is a vent.
It is most likely the condenser box is blocked with fluff and will require cleaning or replacement. I imagine the appliance is not drying very well if at all
Apr 02, 2010 | Miele WT945 Front Load Washer / Dryer
Melie washer/drier wt945 dryer not working
the motor which controls the movement of the fan is either gone cracked or getting faulty or gone weak.needs to be checked and cleaned or replaced.
Jan 29, 2009 | Miele WT945 Front Load Washer / Dryer
Miele WT945 Front Load Washer / Dryer Logo
261 people viewed this question
Top Miele Washing Machines Experts
Marvin
Marvin
shaun taylor
michael_t919
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
