Question about Whirlpool GS6SHEXNS Side by Side Refrigerator
Water dispensor quit working
Ice maker still works, have replaced the water inlet and the water filter. I know I am getting water to the bottom of the freezer door , there is a coupling there and when I disconnect it there is water there, but between there and the dispensor something is not working. I checked the door switch and got continuity and the light comes on and off.
  • 41 Answers
The water line that runs from the bottom of the freezer door up to the water dispenser is probably frozen. I have run across this problem several times. you can take the line out of the freezer door, thaw it out and re-insert it, but chances are it will happen again. usually when you have that issue, there is a problem with the insulation in the freezer door and you will need to have the whole freezer door replaced. Joe
Posted on Dec 03, 2008
2 Suggested Answers
  • 4793 Answers
SOURCE: Kenmore Elite, Bottom Freezer. Ice maker quit
try a full unit defrost clean out vents/drains.
Posted on Feb 22, 2010
No water in water dispensor
Don't forget that your dual water control valve has two sides. One side is for the ice maker and other side is for water dispenser. The water dispenser side may have recently failed causing water to not enter water filter area or dispenser, Thanks Sea Breeze
Feb 21, 2012 | LG LRBC22544 Bottom Freezer Refrigerator
Hello. My side by side refrigerator model MSD2434GE, serial no 11874215CG , I can not get water from the water dispensor, I ice dispensor works fine, I have tried pressing the lock three times but still...
There is valve at the back of the ice maker unit.This valve is the one unit with twin inlet.From one inlet the water enters the ice maker and from other inlet the water enters the water dispenser.so in that valve the ice maker side is working but water dispenser side is not working.Or the ice is got clogged/ over frosted in the water dispenser entering pipe.either the valve needs top be replaced or the water dispenser pipe needs to be checked.Calling service person is advisable.He will just check and confirm what is the issue, the water valve or the over frost build up in the water dispenser tube.and do as required to solve the issue/.If case if the water valve needs to be replaced then cost of water valve is approx $40.------------- this will help.Thanks.Helpmech.
May 29, 2011 | Maytag Refrigerators
I have an Amana ARSE66ZBW The ice maker quit working and would not get water to the ice maker. I replaced both the primary and secondary water valves thinking that was the problem but water still wont go...
mike : ck the inlet to the ice head inside the freezer it will be frozen and need to be de iced .. then see if there is a trough instead of the tube for your model most have this upgrade and it prvents the ice build up at the point . ,, hope this helped mmm fed back pls ..
Feb 25, 2011 | Refrigerators
Ice maker is not working
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
The water dispensor and ice maker have no water pressure. There is plenty of pressure up to the filter but very little past the filter. The filter is new.
the water dispensor and ice maker have no water pressure.There is water/pressure up to the inlet water point to the fridge but no water past the first valve
Aug 17, 2009 | Samsung RS2630SH Side by Side Refrigerator
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Water Dispensor and Ice Maker Not working
Make sure you have water coming to the water inlet valve and then check to make sure that your water filter is pushed all the way in. Next check your solenoids in the back of your fridge. With the power off take an ohm meter and test across the two terminals and it should not Ohm out or beep. If it does you need to replace the solenoids
Jan 04, 2009 | Refrigerators
Whirlpool GS6SHEXNS Side by Side Refrigerator Logo
169 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
