Qc580x-4sg65a-xdo3gk-6ouw03 what dose this code mean and how can it be fixed please.
  • John Anderson
    John Anderson Jun 19, 2012
    whats the code for? looks more like a product key for a product to me.
    Top Expert:
  • 4,961 Answers
It's a product key for an installed piece of software on your computer. Don't tell us which one or it will get pirated and probably become unable to receive updates or even de-activated.
Posted on Jun 19, 2012
SOURCE:
What dose code 0002 means in canon ir 2520
that error means there is over temperature detection . you need to clear that error from service mode
May 04, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
What dose code 0002 means in canon mf4410
Hi the only error codei i could find for this model MF4410 printer .,is E202-0002 fault description ::: contact sensor HP error,Failure in return remedy. Check connection of flat cable between main control board (J5) and contact sensor . (2) replace flat cable between (J5) and contact sensor (3) replace the contact sensor (4) replace the main controller board.:::: good luck
May 02, 2016 | Canon Office Equipment & Supplies
I have daikin n81 air con, its showing f3 code on the control panel what dose this mean
f3 error is a bad thing, it means excessive compressor temperature in outdoor unit. Overheat condition outdoors. Please find a daikin factory authorized service tech in your area to come check it out. These units are awesome when they work, but when they don\'t, normal HVAC techs tend to not want to touch them. They will try to sell you something else. Or even worse, they want to vacuum and refill them for no obvious reason. A 200 dollar maybe fixit.
The daikin units work more like a tv or a car than the old school air conditioners. They have remote controls and service menus and scan tools and such. A veteran daikin tech can diagnose your system fast and give you a wise estimate of what you need. You may just have a leak, or there might actually be something mechanically wrong outdoors.
I would not push my luck and try to run the unit with this error code. Please don\'t let the magic smoke out of your system.
please mark my answer helpful.daikin ductless
Jan 04, 2015 | Heating & Cooling
P0500 code what dose it mean
check the wires at the speed sensor, depending on what unit you have its usually on bottom of rear transmission. I just replaced mine, must have been a stick that hit it and broke the plug.
Sep 02, 2014 | Arctic Cat 2013 Prowler 700 HDX
1989 dodge datona 2.2 turbo coge 13
hello i got a 1990 dodge daytona shelby the code 13 is MAP sensor signal to the computer (ECU) not changing so the map sensor is should be on the firewall with a vacuum line on it little black box looking thing well make sure it plug in and good and that it dose not have a leaking vacuum line if that dose not work you have a bad map sensor thay run about 30 to 100 at auto zone o onec you think you fix it remove the battery term for about 5 mins with the key on and trun the key off before conttecting the battey back up drive for about 20 mins to see if the code show up if you get code 55 all that means is end of falt code list you mite get a code 12 meaning The battery has been disconnected and the computer (ECU) has been reset hope that help keep that daytona runing it a good car
Oct 07, 2009 | 1989 Dodge Daytona
WHAT DOSE E7 ERROR CODE MEANS
Don't know what that code means but....
On my DVD-LV50, I was able to re-initialize and fix a different error (error code H05). It might work for you, too.
With no disk in the player, press and hold these buttons for 4 seconds:
  1. Back skip -- [ |<< ]
  2. Pause -- [ || ]
  3. Play -- [ > ]
The screen will go blank, then say "Initialized."
After that, it worked like new.
I hope that helps.
Aug 10, 2008 | Panasonic DVD-LV50 Portable DVD Player...
7150C Error Code #54
This error means your purge unit is not working. Most likely there is a piece of paper stuck in the unit (or other object).
You will have to take the unit apart and check for objects inside that should not be there. Also, check to make sure the excoder strip is seated correctly in the printhead (this is a long clear strip that goes from one end of the unit to the other).
If neither of these fixes the error, then the purge unit would have to be removed, inspected and repaired or replaced.
Feb 22, 2008 | Brother MFC-8220 Fax
Computers & Internet Logo
27 people viewed this question
Alun Cox
