Question about HP ScanJet 5370C Flatbed Scanner
How to remove & reinstall HP 5370C Scanner & 4315 All-in_One
Both were working OK. Tried using 5370C and got messae "Sorry, couldnot access your scaner, your scanner is currrently being accessed by another aplication" Had previous trouble with USB cable so purchased a new one, installed it in the Scannere but not the PC. A few days later PC showed Scanner ready to work (USB still not connected to the PC), tried scanner and it worked. Now it does not, and dont' expect it too with the USB not fully installed. A 'whiz kid' says to remove and reinstall both units (I'm a 87 year old Geezer trying to learn something), but I don't know the correct procedures to go thru to remove and reinstall the 5370C Flatbed Scannere and thh HP 4 in 1. Any information would be helpful but keep it in as non tetical language as possible.
How to uninstall the software depends on your operating system. If you have windows XP, click on the Start buton, select "Control Panel". When it opens select "Add of Remove" programs (lcick). Wait for the list of progrms to appear and then look for the HP Scanjet software. Click on it and you will be given the option to uninstall. Click to uninstall. When the uninstall has finished, restart your computer and begin the process of reinstalling the software provided by HP again. If you do not have the software, go to www.HP.com and in their "sopport" section enter Scanjet 5370 in the search list.It will give you 3 options, depending on your scnner model. You should probably select the first option 5370c. click on it and it will take you to software downloads. Select the most recent and largest file to download. This will provide the latest software for your 5370. Run the program, restart (reboot) your computer,THEN plug in your USB cord. The computer should tell you that new hardware has been found. Follwo the messages on the screen and (hopefully) your scanner sill woork. The process for Windows 98 and Vista is similr to what I have outlined for Windows XP. Good luck
Posted on Mar 02, 2009
Pilote HP 5370c windows
Sorry your question is not clear to me.Can you please elaborate so that I can solve your problem?
Jan 13, 2011 | HP ScanJet 5370C Flatbed Scanner
How can I get ScanJet 5370C to work on Vista Premium with my Gateway Computer.
Unfortunately HP have not created any drivers for your Scanner for Vista and I have been informed that they are not planning to either.
There is a "work around" If you download Microsoft's Virtual PC and install a copy of windows XP you would then be able to scan using the "Virtual PC" inside of your Vista operating system. Otherwise the only way out is to purchase a new scanner Sorry to be the barer of bad news
Jul 20, 2010 | HP ScanJet 5370C Flatbed Scanner
My HP 5370C scanner no longer works. When I tried to scan, a blank white image appeared. Tried a few more times, same thing. The next day I tried scanning again a pop-up appeared indicating ,no scanner...
The problem is in the connection cable, Check the cable that connects your scanner with your computer, If still not working, try replacing it with a new one.
Jan 26, 2010 | HP ScanJet 5370C Flatbed Scanner
XP won't recognize HP 5370C Scanner
go to contol panel and select new hardware. then try it by reading that instruction. if its no result then u can reinstall ur Xp
Aug 03, 2009 | HP ScanJet 5370C Flatbed Scanner
HOW TO INSTALL hp scanner to VISTA
Right Click the Setup.exe file- - - ->Select Properties- - - ->Select Compatibility- - - - ->Select "Run this Programme in Compatibility For" Windows XP Service Pack2- - - - ->Also in Privilege Levels, select "Run this programme as an Administrator"- - - > Apply - - - > OK.
Now install the Scanner again with this Setup file and I'm sure you can install your Scanner in Vista and it will work for sure.
Hope this will help you.
May 02, 2009 | HP ScanJet 5370C Flatbed Scanner
Windows XP not recognising HP ScanJet 5370C
If its a new computer, but with the same software, don't you think it would be the computer's problem???
Apr 12, 2009 | HP ScanJet 5370C Flatbed Scanner
HP ScanJet 5370C
Replace the R 105 with a 30E one.
I read somewhere to remove the C118, it can work without
Dec 15, 2007 | HP ScanJet 5370C Flatbed Scanner
HP ScanJet 5370C Flatbed Scanner Logo
324 people viewed this question
Ben Johnson
