Question about OKI Office Equipment & Supplies
OKI OL410 printer. Paper does not want to feed through - jams when about 3 inches into printer. Roughed up rubber wheel - no difference. Have to push paper to get to to go through. Sometimes it skews the paper and stops. Also black band appears across the page. Have to put spare page through first to clean it OK for the proper sheet. Malcolm Bowden.
  • mb83 Dec 03, 2008
    The black line which I have had for years has nothing to do with the paper feed which is very recent. The black line seems like light getting to the light sensitive roller but it is right underneath. The paper jam seems like a roller is skidding or a friction pad or something on the left is blocking the pathway.
    Genius:
  • 1,239 Answers
Hi Check the feed roller to see if dust hasn't built up. Clean it with a soft rag and some alcohol.
Posted on Dec 03, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 03, 2008
    Did you go into the control panel menu and verify that it is set to pick up from the manual tray?
    There are 2 things that control that roller. One is the motor and the other is the logic board which gives the signal to the motor that controls the take up roller.Since the movement of the roller appears to be normal,the logic board may be at fault. Unfortunately I do not have the service manual on this model. In any case, you would need service on the unit.
  • ABHISHEK.C
    if any of these doesnt work it is best to
    Cold reset:
    1. Turn the printer power off.
    2. Press and hold GO.
    3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
    4. Release GO.
    5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
  • 10,515 Answers
I'm still using a 1980's laser printer called a Newgen, so I shouldn't really say "that's quite an antique you're using there".
Out of interest, it isn't a Laser printer, but a LED printer. Instead of writing the image onto the drum with a laser beam, it uses a strip of light emitting diodes (LED's).
Your paper jam problem may not be a paper jam at all, but simply a malfunction of the sensor which is meant to detect a paper jam. Or it may be a tiny corner of a sheet of paper caught somewhere. Or it might be that junior ran a sheet of sticky labels through and one of them got stuck.
Sometimes you can check the paper path by removing the drum (and keeping it in a dark place) and hand-feeding a sheet of paper through the various parts of the printer where there might be an obstruction. But I guess you've already tried that. I once cleared a jam by cutting a piece of A4 paper into a triangle, passing the point through first then once I could see it, I grabbed the point and wiggled the rest of the sheet through. But I've also seen a laser printer that had a doozy of a paper jam -- it had a complete overhead transparency wrapped around the fuser roller, and welded irremovably in place. Let;s hope that isn't it!
By all means contact Oki and see what help you can get. It might take a phone call to Sydney but I'll bet you get some advice that will help you get it going again. The phone number is (07) 3856 2200 in Brisbane and (02) 9690 8200 in Sydney.
Good luck (and please let us know how you fix it......
Take Care.
    President:
  • 2,712 Answers
Make sure there is nothing caught in the rollers. Bits of paper, clips, etc can cause obstruction and cause this issue. Open the cover and inspect the insides carefully. Use a can of compressed air if possible, and a pair of tweezers to remove observable debris.
Also ensure that you clean the rollers with a bit of isopropyl alcohol.
    Sergeant:
  • 237 Answers
A thick black line is often the printed result of a paper feed problem. Ensure you use the correct
paper, and that the printer's feed tray is properly aligned.
  • zabrina liang Dec 03, 2008
    Here is another little printer tip that may work:
    Put in the feeder, a bulk of paper
    If you do put a bulk of paper in at a time, try the oppoite, one piece of paper at a time.
    Printers have their own little temperaments, and you may just need to figure out yours.
    One other note: if you have had this printer for years, it may be time to get a new one=)
    Genius:
  • 1,847 Answers
Check the roller clean it with little alcohol and then try
  • Legin Varghese
    Legin Varghese Dec 03, 2008
    Roll the roller with you hands and check for the bit of paper or dirt. check the inside of the printer for and foreign object.
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
Epson stylus c68 paper jam
Hi Guest.
Turn your printer off and load a single sheet of paper. Move the rubber wheel to anywhere. Turn the printer on and watch what happens in the paper feed slot (in official Epson parlance this is the "automatic sheet feeder" or ASF). You should see the rubber wheel etc set into the correct start postion. Then press the paper feed button and watch again. The plastic "wall" behind the piece of paper should move forward, pushing the sheet into the rotating rubber wheel. This should feed the paper into the "ready to print position". If this doesn't happen, it means something has come adrift inside the paper feed system. To investigate this further requires the printer to be dismantled. Either take it to a technician, or if you want to have a go at doing this yourself, post a new comment to this effect and I will help you do this.
Mar 17, 2009 | Epson Stylus Photo R320 InkJet Printer
The paper has jammed in my ML-1610 printer.
The paper jams mostly, because the rubber band that feeds the paper to the printer is broken/split. Check the rubber band. It's located within the plastic wheel that feeds the paper.
Mar 09, 2009 | Samsung ML 1610 Laser Printer
PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Aug 22, 2008 | Lexmark E232 Laser Printer
Print fragmented documnts
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 14, 2008 | OKI MICROLINE ML-395 Matrix Printer
Printer HP PSC 1610XI
Ink Jet Printers are notorious for this. Try using household dish detergent( or any thing that contains glycerin [C3H5(OH)3] ) on the rubber wheels. It appears that the glycerin in the dish soap replaces the glycerin in the material frequently called rubber.
Apply the dish soap to all exposed wheels.
Let soak for five to ten minutes.
Wipe the wheels clean. Clean up any spillage too.
Run a few sheets of paper through the printer (until the damp/oily wheel marks disappear from paper).
Printer should work like new when complete.
May 02, 2008 | Office Equipment & Supplies
OKI PRINTER B4250
You have accidentally pulled the back paper tray. Even when pulled a little, this tray tells the printer to deliver output to the back. This is useful when printing on heavy, or thick paper. Just push it back all the way down to it's original place.
Sep 03, 2007 | OKI B4250 Led Printer
29 people viewed this question
Top OKI Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
