Question about Maytag Performa PAV3200
Machine vibrates terrible on spin cylce
We recently moved and since then my machine will actually walk across the floor while in the spin cycle. I made sure it was level and it will do it without a load of clothes. What could have been knocked out of whack when I moved it?
  • 1 more comment
  • kbrich27 Nov 18, 2007
    Experiencing the same issue with a PAV3300...is that covered under the SF-26-756 you mentioned?
  • Frumper Jun 03, 2008
    Having exactly the same problem on a PAV3300 - it gets so out of balance that the tub hits the side of the washer and it will walk across the floor (yes, it's level and the floor is a concrete slab covered with ceramic tile)
  • Anonymous Mar 26, 2014
    Machine will not start at times. It also will not change thru cycles stopping without spinning the clothes.
    Problem Solver:
Another suggestion, I don't know anything about snubbers and all that. But I had a few machine want to walk across the floor. Several repairmen and other people had told me to buy a peice of plywood, roughly 27"x27" and put it under the machine. It worked for me. I guess the idea is that the subfloor in your new house flexes cuasing the machine lift and walk. I have heard of brand new machines doing this in houses with certain floors. There is an antiwalk kit that is sold too the kit is very similar to a horse pad, a thick very stiff compressed rubber mat. The kit being a solution to aesthetic problem of the plywood. (if you think the plywood is ugly)
Posted on Feb 02, 2007
    President:
  • 878 Answers
Mom2, sounds like you are going to need a new snubber kit. Maytag had a service flash on this, regarding vibration in spin. The snubber kit includes 6 new springs along with the snubber. This can be a bear of a job so you might want to call Maytag and inquire about SF-26-756. It should be covered. This is for model pav3200aaw, but there is a bunch of others too. It's possible that during your move the snubber became off center. If your basket is leaning to one side, you can be assured this is the problem...Catriver..post back.
Washer makes loud banging noise on spin cycle and walks across the floor. The drum rotates fine on other cycles and belt seems to be intact
Have you removed the bolts at the back of the machine. they are there to help stop it getting damaged in transit but if left in when in use it vibrates violently and moves a lot read manual and look at back to see if bolts are left in and remove them if so. hope this helps.
Dec 28, 2010 | Samsung WF337AA Front Load Washer
On the spin cycle my miele walks acrossed the floor
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 06, 2009 | Washing Machines
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Jun 01, 2009 | Whirlpool Inglis IP4400 Washer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Walking during the spin cycle
Is your floor level, first thing. Okay, the rear 2 legs are not adjustable so leave it. The front 2 legs should be screwed up (ie the machine should be at the lowest level in front) and there are check nuts to tighten inside the body of the machine. Check the machine it it rocks by using your hand against it. Adjust accordingly, this is if your floor is not too good. You shd not hv any problem. If the rocking persists check inside machine, behind after getting he plug off wall, maybe shockabsorbers hv come off, springs?.....
and rate me please if helped.............
Jan 12, 2008 | LG WM2277H Front Load Washer
Washer walking across the floor in spin cylce
This machine uses an auto-adjust for the back portion and they tend to get stuck. Since it sits on a common chassis, insert two standard legs in the back. There are threaded holes that the legs go in. Rebalance the machine. Your problem should stop.
Dec 20, 2007 | Maytag Legacy Series Top Load Washer
Severe vibration on spin
tilt the machine back and check that the blue clips that secure the suspension legs to the base are in place and both the legs are secured top and bottom.
Dec 18, 2007 | Whirlpool AWM6120 Front Load Washer
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
853 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
