Hi we have broadband and lately i have to keep turning off modem to connect to the internet. this fixes it for awhile then have to turn off again? please can you help
  • 345 Answers
Do you have a router connected to your broadband connection? If so, you might have to update the firmware on that router. If you don't have a router on your broadband system, I would get in touch with your Internet Service Provider to see about a replacement modem.
Good Luck
Posted on Dec 03, 2008
My Wireless-G Broadband Router was working fine until yesterday when I lost the connection. I have tried everything I know to do to get the connection back. I turned off all the computers; the modem, and...
If you can access the configuration page of the router then check the IP configuration. Check WAN and LAN configurations. IP 192.168.1.1 or 192.168.0.1 will able u to access configuration page. Username and password hopefully be admin admin.
Regards;
Hasan
Dec 27, 2009 | Linksys Wireless-G Broadband Router
Tip
HOW TO SET UP SPEED TOUCH 5X6V6 BROADBAND MODEM
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
Operating System is Windows 7
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from front page
menu will open and display
DSL & Internet Connections
here we test internet functionality.on? or off?
Now we go to your computer,
go to start
my network connections
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
or
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
on Apr 18, 2010 | Computers & Internet
Hi - My 2wire 1701 gateway has steady green power light and steady local network light but the broadband link light is steady amber. My computer is receiving the WiFi signal but I cannot get any internet...
The broadband link light tells you the status of the connection between the modem and the broadband servers in your area. Green means everything is A-Ok while amber means your modem is not picking up a broadband signal.
Try turning the modem off and on and also make sure the cables are secure while you're at it. If the broadband light is still amber, the only thing you could do next is to call your internet service provider.
Oct 01, 2009 | 2wire Computers & Internet
Wont connect to internet
Well in case it always try you to connect through dial-up.
Check the option (connect to and change in broadband, in case you using a aol software to connect to internet
Hope this will resolve your issue.
Sep 25, 2009 | D-Link DU-562M Modem
D LINK DI 604 KEEPS KICKING ME OFF
are any lights going off or flashing on mdm ? then call isp . . when was the last time you pwr cyc mdm AND router if it has been awhile try that turn both off for for 3 to 5 min turn mdm on first wait for dsl light wait 2 min turn router on wait 2 min try again if still have problems connect direct to mdm and if still doing it it isn't the router it is the internet connection or mdm
Apr 07, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
I have had a wireless dynex router for awhile and it has been working fine using wireless then when i plugged in my computer and xbox 360 to the router it has made the computers using the wireless internet...
it is getting limited or no connectivity because it is actually not connected even though it shows.the best resolution is that change your entire wireless settings and then connect all wireless devices like computer and xbox 360 again it will connect.I use to do the same when i use to work for netgear.
that will fix..
Jan 04, 2009 | Dynex DX-E401 Router
Connected to internet but cannot browse.
hi there ;
there is no such solution for ur problem ..... the only solution is to firstly reset the router for 30 seconds and then upgrade the firmware of the router ..... remove the powercord for 10 seconds ...
> Again redo the settings then ....
Nov 14, 2008 | NetGear WGR614 Wireless Router
ACCESSING MY LINKSYS
Hi Sorry for the late reply.
Do you have a phone number I could call you on?
Thank you!
-Cameron Bradford
Also, you can visit my website www.pc-fix.us
Aug 19, 2008 | Linksys Wireless-G Broadband Router
Broadband 2nd Light keeps blinking yellow and then a solid red Light
Ask your Paents to ring the company they connect with it seems to be emulating a disconnection for some reason?
Sep 05, 2007 | 2wire (1000-000057-000) Modem
Blinking 2nd light - Broadband connection light
Its disconnected ring the ISP or your Parents?
Sep 04, 2007 | 2wire (1000-000057-000) Modem
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
