I allowed a kid on the street to play games and ended up with this game - and want to get it uninstalled!!
Help!!!
Sponsored Links
Same Problem
Apr 24, 2009
-   WORLD OF WARCRAFT makes me want to bomb the developer! I cannot uninstall this from my control panel and 'warcraft' or 'blizzard' does not show up in a 'search'.
-   Guest
You can try removing the game from the Add and Remove Programs from the
Control Panel, but if it does not get uninstall from there or if it
gives you any kind of error messages you can try the below mentioned.
Clear temp files1. Click “Start”, click “Run”, type” %temp%” in
the Open box, and then click OK. (If the "Run" option is unavailable press the "Windows Key" and "R" (The "Windows key" is between "ctrl" and "alt" keys on your keyboard.) 2. On
the" Edit menu, click Select All. 3. On the File menu, click Delete, and then click Yes to All. Delete the game Folder 1. Click Start, and then click Search or “Find or
Search". NOTE: If you are using Microsoft Windows 98, click "Files or
Folders", and if you are using Microsoft Windows XP, click "All files
and folders". 2. in the Named box or the "All or part of the
file name" box, type Warcraft or Blizzard. 3. In the "Right pane" box, select all
the game related files and delete them.
Uninstallthe game from
registry WARNING: Using Registry
Editor incorrectly can cause serious problems that may require you to reinstall
your operating system Make
sure you delete keys only related to Warcraft or Blizzard . 1. Click on “Start” and click on “Run” type
“regedit”. 2. Click on [+] Sign next to HKEY_LOCAL_MACHINE and
locate Software and click on [+] Sign next to it. 3. Now, press "ctrl + f" (to search) and type the
game name (Warcraft or Blizzard). 4. Delete all the keys and folders associated with
the game that would be displayed in the column to the left. 5. Press “F3” on your keyboard to re-search for
different entries for the game. 6. Then exit the Registry Editor and restart the
machine for the changes to take effect.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Blizzard Entertainment World
try starting a game, but then it says error software emulation conflict. im using a site called...
(More)
try starting a game, but then it says error software emulation conflict. im using a site called metaboli for my games. they just tell me to go to securom.com for my solution.
