Question about GE GSS25LGM Side by Side Refrigerator
My icemaker works fine, but does not dispense water from the door
I have replaced the water inlet valve and the water filter. in the lower front of the freezer door where the water line goes up, there is a coupling and I am getting water to there. from the bottom of the freezer door to the dispenser there is no water.
  • ecesareel Dec 05, 2008
    icemaker works o.k., but will not dispense water.
    Problem Solver:
Had same problem, my despenser water line was froze in the door. Here is the steps I went through to fix. http://www.fixya.com/support/t1383727-got_ice_but_no_water
Posted on Dec 16, 2008
No water being dispense into ice maker. It's doing it usual dumping & everything . The cold water dispenser in the door is working.
Probably a bad inlet valve on the lower back where the house water line hooks to the refrigerator. Its a 2 part inlet valve. Half feeds water to the dispenser and half feeds water to the icemaker. You can't change half--need a complete valve assembly. Not hard to change. Disconnect house line---unplug 2 wiring plugs (4 wires total) and disconnect 2 plastic water lines. Reverse to install---don't get wiring mixed up or reversed.
Jun 16, 2015 | Refrigerators
Ice maker not making ice, but water dispenser working, just changed filter
If you changed the filter than water may not have made it to the icemaker yet. If you have givin it 24hrs than check these.
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Aug 01, 2011 | Whirlpool Refrigerators
My refrigerator water dispenser is not working. I
In the back of the refrigerator there is a water inlet valve. It will have three hoses one coming in, two going out. A 1/4 line for the icemaker and a 5/16" for the water dispenser. If your icemaker is working and you dont have water at the door the valve to the water dispenser is faulty, you need to replace the water inlet valve. If neither icemaker or water dispenser is working chek your water supply line
Feb 22, 2010 | Refrigerators
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
Feb 14, 2010 | Refrigerators
DOES THE THIS FRIDGE MODEL #106.74912401 REQUIRE TO REPLACE WATER FILTER FOR FRONT DOOR WATER DISPENSE?? ITS A KENMORE ELITE
HI. When a filter has reached its filtering limit, it must be replaced. Once the filter has reached its filtering limits, it will not allow for proper water flow. This will affect the operating status of the dispenser. With that being said, there are other issues that will affect the dispensers abilities as well. These issues are a faulty water inlet valve assembly, and frozen inlet lines. If you are having issues with the dispenser, make sure you inspect these areas as well. Your filter should have an installation date on the label. check to see that it is not over a year old. if so, it should be replaced.
The filter is located behind the front lower grille work. The grille should have a cut out space for it to slide into.
Nov 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
No water going in the ice maker but water dispener
Pour about 2/3 cup of water into icemaker . If it freezes and does not dump , replace the icemaker . Check to make sure the coils are clean of dust , lint , pet hair , etc . If it does dump , and does not refill with water , replace the water inlet valve ( piece behind refrig where the wall water line connects to on the fridge ) . Check to make sure the fill tube that fills the icemaker is not blocked with ice , still indicating a bad water inlet valve ( slow seep ) .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Apr 09, 2009 | Maytag MFI2568AE Side by Side French Door...
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Icemaker
check the water inlet valve in the rear of the refrigerator/// do you have a water dispenser in the door?? if so switch the wires and see if the im then fills when pressing the water disp button
Mar 15, 2008 | Sub-Zero Bottom Freezer Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
137 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
