Question about Kenmore 24032\24036 Top Load Washer
How may I get the Kenmore 400 washer's mechanical drawings
    President:
  • 2,992 Answers
Go to www.searspartsdirect.com. You can put in your specific model number and get exploded views and parts information.
Posted on Dec 05, 2008
Kenmore elite washer model 11045087 400 err code hl f?what is this
Go on internet and go to Kenmors , and then from there on kenmore's website say need area code 400 for Kenworth washer model 11040 87 that should help you
Oct 14, 2017 | Kenmore Washing Machines
Kenmore 400 washer where is lint filter
many do not have a lint filter in the washer .
Nov 02, 2015 | Kenmore Washing Machines
My Kenmore 400 series washer does not seem to be releasing the fabric softener properly. It ends up all around the top if the barrel and spotted on my clothes as well. Anything I can do other than g
the dispencer can at times become plugged with old soap and farbic softener and should be cleaned every so often. if it cannot dispinse it will shoot out the dispenser all over when it goes into spin. the lines can even get plugged up and not allow fabric softerner to flow , u may want to remove fabric hoses and clean them
Nov 08, 2014 | Kenmore Washing Machines
Kenmore 400 washer
Try redistributing the blanket evenly around the agitator.
Jun 11, 2017 | Washing Machines
Our 80 series kenmore became unbalanced with a loud klunk. The metal shell came off the machine. It will not spin but will work on wash?
You may be able to find the problem by looking at the illustrated parts breakdown.
Sears maintains such drawing on nearly all of the brand names they sell and many more:
http://www.searspartsdirect.com/partsdirect/
Enter your model number in the provided search window there.
There are also links on how to find the model number if you have trouble locating it.
Jul 02, 2014 | Kenmore 24032\24036 Top Load Washer
I want to find out how many watts does the kenmore 400 series uses
Maybe a dumb question, but what do you need a transformer for a washing machine? Washers typically plug into a standard 120 volt 15 amp outlet. To figure out the wattage, use the simple formula, P=E x I. There will be a tag somewhere on the machine stating current draw, which is "I", "E" is your voltage, and "P" is your wattage which is what you'll figure out after reading the label on the machine.
Jul 23, 2012 | Kenmore Washing Machines
Why won't my kenmore 400 washer spin out?
Sometimes the drain pump goes bad which prevents the water from draining and then spinning. If this isn't a direct drive model then a simply fix to replace the drain pump and belt. Good luck
Jul 10, 2010 | Kenmore 400 6942 Dryer
My kenmore 400 washer fills but nothing else
Lid switch is still most likely the problem. Are you able to unplug washer from wall and check the wire connected to the switch.
Aug 28, 2009 | Washing Machines
How my i find the mechanical diagram for washer Kenmore-400?
take the 2 screws out from the front of each side of console pull forward and swing up ,,, it should be inside there / larry
Dec 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
195 people viewed this question
Sal De
fordexpert
Robert Rankin
