Question about Plextor 1 to 7 Targets 52X CDR Duplicator w/ Drives (BCPT5207) Burner
No target drive and writing speed is seen on the option settings menu of Picture Package software (Ver 1.5)
While trying to burn CD on PC from Sony Handycam, no target drive and writing speed is seen on the option settings menu of picture package menu. Why?
0 characters
1 Points
My cd/dvd produplicator is now only burning cds and not dvds. I am getting error message that says target drive not ready. Is there a solution or must I replace the target drive altogether?
You can try going to manufacturer's website to see if there is a firmware update. You can try uninstalling a reinstalling the application/drivers for the device as well.
Jun 01, 2014 | Vinpower Digital CD & DVD Burners
Unable to get Sony Optiarc AD-7585H to write at slower speed than ~8x
Sure..... open your burning software go into settings and select the burning speed from a drop down menu.
Nov 09, 2013 | CD & DVD Burners
Unable to push Sony Optiarc AD-7585H to write at 1x
You're not "pushing" with 1x speed, that's the slowest speed at which a burner will burn at. You can change the write speed in the burning software settings.
Nov 09, 2013 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
My computer burns dc fine but does not want to burn dvd, I get error message tellimh me that there has been a problem at the very beginning of the burning process. The disks are then unusable. What can...
Hello leslaw176,
Your problem in your burning of DVD will be solve by just using other burning application like Nero DVD burner (which is the most stable and user-friendly software) software and by lowering your burning speed. There's an drop down menu before you burn you DVD which tells you what speed will be using try 16x in DVD. Its better to write normally than writing in full burst.
May my solution may solve your problem.
Thanks for using Fixya...;-)
Aug 19, 2011 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Target drive is not working
on blank cd's or dvd is nothing to read, With burner software like Nero you can write data or music or other content (burning it) on the cd/dvd. Does this answer your question?
Aug 25, 2009 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
In the Sonic program you can change the speed in the preferences/options menu. Hope this helps.
Dec 21, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Sony DVD RW AW-Q170A Burning Problem Plzzz.....Help me out: i have two drives, 1) Sony DVD RW AW-Q170A 1.70 Ver 2) Sony DVD/CD-RW Combo RYK4 Ver My "Sony DVD RW...
Check that the writable DVDs you are using are compatible (+/-) with your Sony DVD-RAM.
Go to Windows Explorer and check to see if the Sony drive is visible. It may not be connected or the Jumper switch may be set incorrectly.
Check you have drivers installed, take a look in Hardware manager.
Sometimes, it's a little difficult to copy CDs and DVDs when you have more than one burning suite installed - for some reason, they 'just don't get along'. Try uninstalling any suites other than Nero.
Or it may just be that your Sony CD-RW drive is just that, and your DVD-RW drive is just that. So it wouldn't be possible to write DVDs on the CD-RW and CDs on the DVD-RW? Though I would assume Nero would detect that and use your hard-drive as temporary storage.
In Nero SmartStart, have you selected the CD or DVD tab to correspond to the project you're burning?
Jan 07, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Problem on burning CDRW
run the nero drive speed first before burning in your files, if your cd in a RW or rewritable, just erase it and burn again the data's that you want.
Aug 25, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
DVD - Slow burning speeds
Unlikely that there is a problem with the drive itself, most likely cause is software settings - which burning software are you using? if it is nero 6 then once you click burn after arranging the files for burning, the burn info page should pop up. click on the burn tab and make sure that "determine maximum speed" is checked and that write speed is set to maximum. hopefully this should solve it, if not try setting write speed to one of the slower settings listed and see if you get a better result. Sometimes dvd drives can slow right down when you are trying to push them to go at maximum. if you want to check what it should be able to do, try also worth trying is updating the drivers to make sure you have the most recent version. Another thing worth trying if you haven't already is try a different brand or type of disc - just occasionally there can be clashes with certain types and burners - if this seems to solve it, don't throw your pack of discs away, give them to someone with a different burner. The final possibility is a power supply problem. If your PC's power supply unit has spare connectors for a drive then try a different one - possibly your supply doesn't have enough guts to run a more modern drive - take the drive out and try it in another pc with a higher power supply wattage rating. Hope this helps :)
Feb 28, 2007 | Sony DRU-820A DVD RW Dual Layer Burner
Plextor 1 to 7 Targets 52X CDR Duplicator w/ Drives (BCPT5207) Burner Logo
328 people viewed this question
Top Plextor CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a Plextor CD and DVD Burner Expert? Answer questions, earn points and help others
