Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher SHU9922UC
When the dishwasher has completed and has been turned off, very slowly water from the supply line continues to enter the dishwasher. After about 4 to 5 hours if I open the door water will come out. I've turned off the water shut off value and this has stopped the problem. Could this be that the dishwasher inlet value is not closing properly? Can this be repaired? Thanks.
  • mollymagee May 07, 2008
    same problem. water supply will never shut off on it's on. i have to manually turn off water supply to dishwasher in order to get it to stop. If I do not shut of water, cycle continues in rinse cycle for hours and water eventually starts to flood kitchen floor. Help.
  • 175 Answers
Sounds like you already know how to fix it. The inlet valve is only held closed by water pressure...if you have low water pressure it could be causing this. Its more likely just a bad fill valve though. The water inlet valve is accessed by removinf the lower kickplate and the sheild behind that. Then all you have to do is remove the water line from the valve, remove the 2 screws holding it and pull it out far enough to disconnect the 2(possibly 3) wires and the fill hose. Make sure to mark where your wires go, if you hook it up wrong it could continue to fill and overflow. Hope this helps!
Posted on Feb 02, 2007
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
The dishwasher makes a noise that will not stop until you turn the water supply off.
sounds like the magnetic switch for the water intake has become clogged and not re sealing its self, you would need to remove the water pipe and see if you can see anything in the switch keeping it open, if not then the switch has gone and needs replacing. it can be that there is no filter on the water line and they could of cleaned the water line and a bit of muck from the cleaning the main water lines has got into the washer.
Dec 24, 2017 | Bosch SHU3306UC Built-in Dishwasher
No water enters the dishwasher when its turned on
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 23, 2010 | Bosch SHV46C03 Built-in Dishwasher
Our bosch shu9902uc dosnt clean the dishes,ive tryed to clean out the drains,blew compressed air thru the drain line,cleaned out the sprayers,still it dosnt clean food off the dishes. water plenty hot and...
make sure you clean the sprayers out real good,if theres debris on the end nozzles they dont spin around too good,also pull out the little service plug that protects debris from getting in the impeller.
i found a little chunk of wood in there! im still not sure how wood ended up in the dishwasher!
Jan 04, 2010 | Bosch SHU9922UC Built-in Dishwasher
1- machine operates with the door open. 2 - water
So if I fixed it you want me to give that info to you for free but otherwise you want to charge me for an answer?
Oct 29, 2009 | Bosch SHU9922UC Built-in Dishwasher
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Turn on, it hums but no water.. the water line is new.
Many new supply lines have a safety valve built in to prevent flooding in case of major malfuction. Floodsaver is one of the brands. They can be identified by a small silver cylinder at the water valve end under your sink. I have found that then valves can close under certain conditions other than a malfunction. Try turning off the supply valve and then very slowly, reopen it. Sometimes, I have had to turn off the water supply valve, disconnect the line to relieve the pressure, reattach and SLOWLY turn the water back on. If this fails, next try the diagnostic procedures here:
http://www.applianceaid.com/boschDW.html#test
best of luck!
Mar 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
No water in dishwasher
You need the check the water level switch which is located on the diaphram of the water fill assembly. This is located on the laft side of your machine behind the metal panel. if this switch sticks it will not allow water into the machine
Mar 03, 2007 | Bosch SHU9915UC Dishwasher
Bosch Dishwasher SHU9922
It is the inlet valve, some are located inside the appliance, some mounted in the back panel. Occationaly some have the valve at the end of the hose in a box. The price for repair the first one cheapest the last most expensive. regards Appliance Doctor
Feb 02, 2007 | Bosch SHU9922UC Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
488 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
