Question about EliteGroup 945P-A (945PA11) Motherboard
I was overlocking my cpu and video card and the screen went black and i was wondering if there is a way to rest my bios
Thank you so much!!! your the shiznit! =)
Posted on Dec 03, 2008
    Scholar:
  • 57 Answers
Here is a typical CMOS jumper reset setup. The pins may not be oriented as it is shown, but this is certain. The way they are now set on the motherboard is to run normally, so the opposite connection needs to be done as it shows. I don't know the specific location of the jumper, so you will have to find it.
Will not power up
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 13, 2012 | Dell Inspiron M5030 Laptop Computer 3D...
Dell inspiron beep codes
These are the Dell beep codes.
DELL BEEP CODES
Oct 11, 2012 | Dell Inspiron M5030 Laptop
Why is my lap top just intermittently beeping with a black screen
DELL BEEP CODES
Oct 07, 2012 | Dell Inspiron M5030 Laptop
PC show the message and hang and black screen .
You are going to have to start with basic troubleshooting first.
TAKE notes as to where cables were etc. (digital camera would be useful here)
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the on-board)
Disconnect all drives
Power u the computer and make sure you can at least get into the BIOS.
If you hear any beeps these can indicate where the fault is.
Power up the PC and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
If its not the PSU and your fans are working it may suggest a problem with either the motherboard or CPU
Sep 05, 2009 | Computers & Internet
Black screen on boot on biostar mcp6p m2+
That board has a built in video card if I have the right info. If you are using an external video ie plug in card then you need to make sure the onboard video is disabled or that the plug in card is designated as the main video card. Not doing either of those will cause the black screen.
Aug 10, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
Screen went dead, unplugged the graphics card and
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Could be bad ram, motherboard, cpu, powersupply, videocard.
If the video card is suspected to be damaged, try it in a other pc (friend's, mom's or dad's, pentagons' ).
if it is bad, there is your answer.
Jul 06, 2009 | XFX Computers & Internet
Overlocked my Intel Pentium 4 3.00 Ghz
You have to go into your bios and see what your front side bus and memmory speeds are. If you overclock you cpu, sometimes you need to underclock your memmory. Say step your memmory down to 333mhz and overclock your front side bus(fsb).
Normally your fsb is 200 and only increase it by mhz. Restart, go into windows. and see if it is stable.
I always use cpu-z and gpu-z to check all of my hardware settings. I use ati tool to overclock my x1950 and it is great. There really isnt any good cpu overclocking tools because its better to do it in the bios.
Do a specific search in google for your processor and overclocking.
Jun 06, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
EliteGroup 945P-A (945PA11) Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
