A desktop on my home network will not connect to the internet. Connection is through a wireless router (Netgear WPN824 v2). Other machines on the network have no problem connecting. I've tried troubleshooting with another expert on FixYa, but could not break the jam. Ideas?
  • 1 more comment
  • Curtis Richner May 11, 2010
    Has it connected before?
    Does it have wireless or is hard-wired?
  • Rod
    Rod May 11, 2010
    what os are you running on this one and the others
  • James Hughes May 11, 2010
    Can you ping the router?
  • 61 Answers
Check your hardware ie pins etc...
Posted on Dec 03, 2008
Netgear wpn824 v2 loses connection The internet light blinks amber every few minutes and I lose connection to the internet.
if you're online and loses connection every couple of minutes,that most likely be and issue with you ISP. it's intermittent connection issue with the server or might be the modem if it's more than a year.. better is to contact your ISP to check on their end,also to create a work order to investigate and monitor the issue.
Oct 07, 2011 | NetGear RangeMax WPN824 Wireless Router...
I have a desktop pc that I connected a Netgear WPN824 V2 to. I had to do a complete system restore and lost my connection to the internet completely. I have a laptop and a seperate desktop connected to the...
If you are connecting wired to the router, you should be able to just connect an ethernet cable and the pc will pick up an ip address automatically, and presto - you have internet.
If this is not happening, please check device manager and make sure that the network card is being detected properly, and is not in an error state (yellow circle with an exclamation mark). If it is, you should download the correct driver for it on another pc and install it :)
When you say 'complete system restore', I'm assuming you reinstalled windows from scratch. If you did this on a brand name pc, with the restore discs that came with it, the network card driver would have been installed as part of the setup routine. If you are using an add-on wireless card, then the driver would not have been installed when you reloaded windows, and you need to get the correct driver for your version of windows. If you reinstalled windows with a regular OEM or retail windows cd/dvd then I'd bet it's drivers for the network card.
Hope this helps!....let me know if you get stuck.....
This is likely what's going on.
Aug 17, 2009 | NetGear RangeMax WPN824 Wireless Router...
Lost setup DC
The router is compatible with any operating system. You don't need to use the CD that came with it to setup the internet connection. Just open the router's setup page by typing http://192.168.2.1 on your browser. There you can see the automatic setup.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
My Netgear WPN824 v2 router is not sending a wireless signal
- Updating the firmware of your router will do to fix the issue.
Mar 16, 2009 | NetGear RangeMax WPN824 Wireless Router...
I have wpn824 it appears connected
Try to reset the NetGear router and reconfigure it again Use the user manual for the procedure. If you can not locate the manual use this helpful website below there is 2 version of Wpn824 v2 and v3 but i think configuration should be the same Just pick one. And look under the
knowledge base
http://kbserver.netgear.com/products/WPN824.asp
good luck
Feb 18, 2009 | NetGear RangeMax WPN824 Wireless Router...
No internet despite network connection
ok your problem is the home edition for some reason there are features that are missing compared to all xp versions and i'm a little surpise with vista because of none problems but check all your network settings on all computers but start with the home edition the pproblem one make sure the sttings areset and there are a few things that might not be turned on that has to be check under the add and remove program components but sometimes this area might request the os disk to make changes and also check under network settings that the log on in the network properities is client for microsoft networks then goto internet protocol the address should be obtain auto and very important under internet protocol click properties then advance then at the top click the tab at the top that say options then you will see tcp/ip filter click properties and make all checks are enabled and permit all which is the common for this to be turn off and also i like to make windows the wireless default control under the card configure properties.. but again the home edtion has some features that are not available compared to xp pro which is the best xp os of xp versions....
Dec 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear RangeMax WPN824 Wireless Router (WPN824NAR) Wireless connection drops in and out regularly but frequency of this is unpredictable duration is usually a few seconds. Works find on direct ethernet...
Upgrade the Firmware of the router :
First you should check the version of you WPN824 (v1,v2 or v3). If there are no Version after the model number, it should be a version 1. Download the Firmware of your router given the correct version at this link :
This is assuming that other wireless laptops has the same problem onyour wireless router. If other Laptops works great on your wirelessrouter without dropping any wireless connection, then you shouldconsider upgrading the wireless adapter on you own laptop.
***(If you haven't tried connecting otherwireless laptop wirelessly to the netgear, then you should try it firstto be sure that the netgear is the problem)
Steps on how to upgrade Netgear firmware :
  1. Download the correct file depending on your location and unzip the file to a convenient place such as your desktop.
  2. Log in the router at http://192.168.1.1 or http://192.168.0.1 (or www.routerlogin.net ) (Which ever will work)
  3. Default User name : admin / password : password
  4. Click Maintenance > Router Upgrade.
  5. Click Browse and locate the file you just downloaded.
  6. Click Upload. While the firmware is loading, do not interrupt the upgrade process.
***Therouter reboots when the upgrade is complete.
***Tocheck that the upgrade was successful, log in to the router again at http://192.168.1.1and check the firmware version.
***DONOT UPGRADE FIRMWARE USING A WIRELESS LAPTOP/PC
Oct 26, 2008 | Computers & Internet
Hello
is your office have internet connection?what i mean is the ISP Provider?
Sep 02, 2008 | NetGear RangeMax WPN824 Wireless Router...
Neatgear wireless router wpn824 v2
Windows, if that's what you're using, may be connecting to a different router than yours. Verify that you're connecting to your access point.
Also, make sure there is a good connection between the router and your cable or dsl modem.
Finally, you can try connecting your computer to the router using an ethernet cable. That will at least let you verify that the computer and router work together, and you can configure the router and so forth. If connecting with a wire succeeds, that narrows the problem down to the wireless network connection.
Here's the manual. Troubleshooting is near the end, but it doesn't look like your specific problem is listed...
http://kbserver.netgear.com/pdf/wpn824_ref_manual.pdf
Jan 08, 2008 | NetGear RangeMax WPN824 Router
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
