Question about Kenmore 63942 Dryer
Kenmore 70 series dryer cuts off after 10 minutes
I have a dryer that ran for 10 minutes and stopped working. When I push the button to restart the dryer all I get is a humming noise while holding the start button in. Can you please tell me what the possible problem is.
Thanks
  • 333 Answers
You first shoul check the belt to see if it is not broke or twisted. If not then your motor is heating up and thios causes it to stop. a new motor would be your problem.
Posted on Dec 02, 2008
Kenmore series 80 heats and turns fine but stops after 30 minutes or so at any heat setting
Does it restart after it cools down? If so your motor may be overheating and shutting down.
Jun 20, 2012 | Kenmore series 70 80 90 Dryer Motor...
Kenmore 70 Series Electric Dryer will not start
It sounds like the hi-limit thermostate and/or the thermal cut-off is what is causing your dryer to shut down. Basically it's over heating. You should replace these two items togeather. Also the thermal cut-off will be triggered by a grounded out heating element. Here is a diagram of where these items are located. hope this helps
Figure W-6: Dryer Rear Access
Feb 27, 2012 | Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
I have a kenmore series 80 electric dryer. It will will run for around a minute and then cut off. seems to be over heating. when I turn the heat setting down to the lowest setting it will run longer. If I...
that sounds like the dryer motor going bad,most of the time they run alittle then stop,or when you push the start button it just buzzes-mike
Mar 02, 2010 | Kenmore Dryers
Dryer stops working after 10 minutes
Motor may be over heating.may need new motor.
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
Kenmore Dryer 90 Series will start but suddenly stop...
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Kenmore series 70 mod#110.62722100
check the door switch first if it is ok ..(doors not popping open) then the PTS (push to Start) switch is most likely bad as it wont hold in after it was pressed
Jan 25, 2008 | Dryers
Kenmore 63942 Dryer Logo
187 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
