Question about Dryers
New off the showroom floor whirlpool estate dryer, worked fine for a while, now it won't ignite, what do I do?
  • 41 Answers
Most likely, either your ignitor is bad, your thermal fuse is bad, or your coil set is bad. if your ignitor glows but the gas does not turn on, then your coil set is bad and the other 2 parts are good. Joe
Posted on Dec 03, 2008
It dosn't dryer ,it rotates but won't heat up. I cleaned vent and hose
Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.
If this helps please come back to Fixya and rate my advice!
Jul 27, 2011 | Estate Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
REPLACING HEATING ELEMENT IN ELECTRIC ESTATE WHIRLPOOL DRYER
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 27, 2010 | Whirlpool LEB6300 Electric Dryer
My whirlpool estate electric dryer stopped heating up. Everything else works fine. Is the problem the heating element ?
heatman101
May 31, 2010 | Dryers
I have a Estate Whirlpool model#TGD5740. Smells like smoke when running. Still drys with heat and runs fine. What would cause this
You could have a build up of lent inside the dryer which might have ignited. Dryer should be dissasembled and cleaned.
Could be that your motor is over heating.
Depends on what type of smell your smelling;.If its the motor over heating, motor would have to be replaced.
Dec 27, 2009 | Estate EED4300SQ Dryer
ESTATE DRYER BY WHIRLPOOL TO SWITCH DOOR FROM LEFT TO RIGHT
Look in the whirlpool wedsite for you make and model and for spare parts list.
Jan 11, 2018 | Estate EED4300SQ Dryer
Whirlpool Estate Dryer TGDS840JQ1 dryer runs but does not heat up to dry the clothes.
when you say heat up is it at least getting warm...
you may have a igniter gone bad or your thermostat may have failed... your igniter is what has to ignite the gas to burn to make it hot. If its electric then your heating coil has failed and needs to be replaced
Jun 08, 2009 | Whirlpool Dryers
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
