Question about Whirlpool Duet GHW9150P Front Load Washer
Bang heard a bang, drum runing slow, hear a banging while moving, drum seema lopsided
  • 8 Answers
If your machine is 5 years old or so you might want to check out my post at:
http://www.fixya.com/support/t1254687-duet_washer_very_loud_when_spinning
Posted on Dec 04, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
Yo can try pulling off hte lower access panel 3 screws across the bottom panel, from there yoll be able to see whathappened, perhaps he shock aborbers snapped off, if not htere is a spring that the tub hangs from mounted across the top of frame. 1 on each side
Posted on Dec 03, 2008
Whats wrong with Dryer
The drum slides at the front are made of felt. Yours have worn away. The drum is banging up and down. If you open the door you will find that you can lift and lower the drum. If you drop the drum, you will hear it bang. They are easy to replace if you can get the front off the machine.
It could also be that the rear drum bearing is worn, but that doesn't normally make a banging noise. It is a metal spindle attached to the drum into a nylon sleeve in the back of the machine.
Nov 04, 2015 | Dryers
Inglis Gas Dryer... mercy me?
Sounds like what you said. Time for a motor. The motor has an internal overload and will shut the machine off if the motor runs hot.
Good Luck
Feb 26, 2014 | Inglis 6.5 Cu Ft Super Capacity Gas Dryer
Drum wont spin looks lopsided
The "Guides" around the drum are worn out or the bearing is bad, which usually causes it. Replace the bearing and guides. You Tube has many videos on these fix's. and there is a good chance your machine will have one to view.
Nov 29, 2013 | LG Tromm Front Load Washer And Dryer Set
Inglis dryer making thumping sound when drying
is the unit level, open the dryer try moving the drum around, see if the drum loose, there mite something in the machine that got caught on the drum some how and when it goes around it bangs,
you mite try spinning the dryer without turning it on and listen to the drum and see if you can hear any thing hitting the drum or what is make those load sounds. if you cannot turn the drum manually you mite bribe a guy or friend to check it out for a beer or glass of wine, and if they down drink bake some cookies.
good luck rod
Dec 04, 2012 | Whirlpool Inglis IP8200 Dryer
I have a Kenmore 417.44102300 front load washer. Yesterday as it approached final spin the drum was spinning at top speed as it usually does and all of a sudden it was like something let go and it started...
Possibly a broken bracket we see this happen frequently, with this type of model the parts are kinda high for this repair, look at picture in bubble.could be the shocks I don't think so.fgonzalez278.png
Mar 10, 2011 | Kenmore 44102 Front Load Washer
My whirlpool top loader bangs around during final spin
Kindly provide few details :-
1. Make and model of the washer?
2.How old the washer is?
3. Is it banging only at high speed or even on slow speed?
4. Is it only during the final spin or all the time during spin?
5. If you move the drum by hand, is there any noise? Could you turn the drum easily?
Kindly answer all the questions.
Thanks!!
Sep 02, 2010 | Washing Machines
Hi all i have a big problem heard a big bang the
When it was fitted did the installer remove the transit bolts from the rear of the machine because it sounds as if it has done damage to the drum and housing when it went into a spin.
Hope this helps.
Good Luck
May 09, 2010 | Washing Machines
Model DDG7189VTLWH heard a bang and drum stopped
I would say that you are probably right in your assement of the problem.
For more info on your problem, check out this tip...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 26, 2010 | GE Dryers
Loud banging noise during washing cycle. Sounds like agitator is slipping,then banging. No noise during spinning cycles.
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
This part is the most likely cause of the noise.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | GE WBSR3140DW Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
152 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
