Ricoh aficio 150 paper jam
I have a aficio 150 and replaced the fuser unit - the paper jams in the the side door , if i use the by pass it still jams
Help please
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is the jamming in the fuser section?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
There are pressure release levers on the fuser --- if they are not in the correct position they will not apply the proper pressure and you will get jamming in that area. The levers are either a light green, light blue or plain black. They should be on the left and right side ( looking in at the fuser. Turn/ flip them and check.
Posted on Jan 07, 2009
I have af 2035/45 ricoh i am facing paper jamming at exit unit. i have done replaced sensors and bicu board and check all related wiring, but couldn,t find solution.
paper jam in aficio hasnt reset . but you must check all doors .it may be one door in your machin is open .more than more right door check it
Apr 27, 2012 | Ricoh Aficio 1035 Copier
Paper jam was cleared from the bypass tray.. still says paper is jammed.. there is nothing in it
u have to check the paper path sensor located in the door unit .and also check the fuser for paper jam
Sep 15, 2011 | Ricoh Aficio MP1600SPF Copier
In richo 1045, paper is contineus jam in the upper side of fixing unit
Clean oe change the upper fuser roller,fuser roller cleaning roller and clean the lower pressure(red) roller.
Jun 03, 2010 | Ricoh Aficio 450 Copier
I want now what's Common faults in Aficio 2035
THe main problems are toner spill form drom/dev units ..the transfer on the right hand door will have to be emptied every few months. the paper tray paper stops need to be checked as they come out of place and cause paper jams if not set in place..cahrge rollers can be troublesome if not cleaned every coulple of months and may cause dirty image at the sides or lines on copies..dust on laser **** glass can cause faint on sides of copies.. the fuser stripper fingers tat guide the paper need to be checked for toner under the points to stop paper jams in fuser and the lower guide plate entrance to the fuser needs to be cleaned off every now and then to stop crinklin of paper...apart from that good machine
Dec 17, 2009 | Ricoh Aficio 2035 Copier
Ricoh CL 7100 fuser jam.
The grinding noise is the clashing of gears. The fuser is composed of 2 rollers, a metal or ceramic with a heater inside (bulb) and a silicon roller to apply pressure. The 'hot' roller is geared and the silicon roller can be geared or free floating. There is at least 1 paper sensor in the the fuser to let the unit know whether paper is there and there when it should or should not be. Sometimes, the sensor gets slightly dislodged and can actually cause a jam. If you are hearing a gear clash, the paper is being pushed through the machine and instead of being pushed through the fuser, it stops because the fuser rollers are not turning. The rest of the machine keeps pushing, crinkling the paper.
If there is crinkling, then gears that drive the fuser need to be checked. It is this gear cluster and/or the fuser that need to be replaced.
Aug 03, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
Paper a misfeed
not sure if you are talking about two papers jammed in different locations or at different times?
first thing would be to clean the tires that pick up the paper, if too smooth then replace. sounds like a timing issue.paper getting stuck halfway in the fuser c(if no other paper jammed) can be Seperation is off causing the paper to rise onto the drum creating a time lapse, paper tansport belt (in the machine after the drum) is not turning ok, or as simple as wrong size paper Letter in machine but says Legal 8 1/2 x 14
Aug 26, 2008 | Ricoh Aficio 1018D Copier
Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Jan 30, 2008 | Ricoh Aficio AP2000 Laser Printer
129 people viewed this question
jasbo
jasbo
