Question about Whirlpool LGR3624JQ Gas Dryer
Whirlpool LGR4634EQ3 not heating
My dryer will turn but will not dry cloths. I took off the back of the dryer and cleaned duct work. This did not work. When I turned on the heater I saw a glow and then a flame after about 2 minutes. Then the fire goes out and if I leave it on I smell gas. Is this problem related to the coil or the thermastate.
  • sharonhic Dec 05, 2008
    Thanks, where is the coil set located and how much does it usually cost to replace?
    Thanks, I took of the back of the dryer and the housing that covers the tube were the pilot shoots out the fire. Is this were the coil is located or is it through this tube towards the front of the dryer? Only my hand fits through this tube am I in the right location. If not what part of the dryer do I need to disassemble to get the the coil?
  • 41 Answers
Most likely your coil set is bad. is it turns on once, but then doesn't ignite again, your coil set is overheating and not working. it will need to be replaced. Joe
Posted on Dec 03, 2008
  • rbnsn6 Dec 05, 2008
    the coil set is located on the gas valve in front of the dryer. they are 2 round blacks coils. the set runs about $30-$40 dollars. Joe
  • rbnsn6 Dec 06, 2008
    the coils are located in the front of the dryer. if your lint screen is on the top, you will need to remove the screen and the two screws and the top will lift up. after the top is up, there are 2 hex screws ( one on either side on the top of the inside ) that need to be removed. from there you can remove the front and have access to the coils in front. Joe
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 20, 2011 | Whirlpool LER3624JQ Electric Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
My dryer is heating up but isn't drying the clothes
I would be REALLY suspicious of the exhaust vent. If the dryer is heating up and the drum is turning, it has to dry the clothes UNLESS there is no air going through the dryer. Disconnect the air outlet flexible plastic duct at the back of the unit, and turn it on. If there is no or very little air coming out, the inside of the unit will be plugged with lint. If there is lots of air coming out, the exhaust duct or the outside flapper will be plugged. Sometimes if the exhaust is routed through a cold space there will be so much condensation in the duct that it will droop and literally fill up with water.
Sep 09, 2009 | Whirlpool Dryers
Gas dryer does not completely dry
Replace the glowbar ignitor and also the gas valve coils.
Aug 18, 2009 | Kenmore Dryers
Whirlpool dryer doesnt dry clothes
If the dryer heats , dry a load without the duct on . If it dryes fine , then problem still with vent somewhere .
Jul 19, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool cabrio electric dryer heats and tumbles, but clothes don't get dry
remove your duct from the dryer. DRY a few loads,IF the unit works fine with the duct off, You will need to get the vent to the outside cleaned
Feb 23, 2009 | Dryers
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
My Whirlpool Clean Touch electric dryer is not drying clothes very well. It is not getting real hot, and it takes two cycles to get most things dry. Towels and jeans take part of a third to dry. I clean...
IF YOUR DRYER HEATS AT ALL, BUT WON'T DRY THE CLOTHES, 99 PERCENT OF THE TIME THERE IS A RESTRICTION IN THE AIR FLOW. PULL THE EXHAUST OFF OF THE BACK OF THE DRYER AND DRY ONE LOAD. IF IT DRIES O.K., THERE IS A RESTRICTION IN THE DUCT WORK.
CLEAN OUT THE LINT FROM THE DUCT WORK. IF THE DUCT WORK IS FLEXIBLE MATERIAL, REPLACE IT WITH RIGID 4 INCH METAL DUCT.
Apr 16, 2008 | Dryers
Whirlpool LGR3624JQ Gas Dryer Logo
444 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
