Question about Kitchen Ranges
Frigidaire electric 4 burner glass top. Elements all work, oven light, and surface light work, 2 fuses are good. There is no display and keypad is not responsive.
  • 41 Answers
Most likely, your board has gone bad. if there is power to your unit as you describe and the board has no display, then the board is bad. you can try unplugging the unit, taking off the top back section and unplugging the wire connection to the board and reconnecting it. you may luck out and had a bad connection. otherwise, you will need a new board. Joe
Posted on Dec 03, 2008
How do I replace the receptacle for the heating elements on the stove top.
Typically the light is a function of the selector so as long the position of the knob is to the on position it will be on. in order for the burners to work you'll have to replace the connectors, so full current can go through them. also the self cleaning feature refers to the oven meaning you can lock it, turn it to clean and it will get so hot that the build up on the inside will get flaky and then you can clean it once it cools off. I've never seen one that work that well, but it has nothing to do with the glass there is cleaners that you can "rub" kind of like waxing a car and if you have build up on the glass or burned food you can scrape it with a razor laying flat on the glass and scrape the cleaner around will eventually it will peel off.
Jan 14, 2015 | Kenmore Ovens
KitchenAid Electric Range Model KESA907PSS02 surface elements and oven all stopped producing heat after initially being 'on'
You might have blown the thermal fuse. Here is a diagram of your unit.
The fuse is number 37 on the diagram. Check it for continuity. Here is the part to order in case it is bad.
Keep me posted.
Regards,
Richard Roth
http://appliancecafe.com
For all your appliance repair needs.
Dec 09, 2012 | KitchenAid KESC308LSS Electric Kitchen...
We have an 8 year old Frigidaire electric range. When going to use the oven a few nights ago, we discovered that neither the top or bottom oven burner was heating at all - tired both Bake and Broil. The...
You will have to check that the switch is is working ok , with a vault meter check for voltage at the burner , if none check at the switch and so forth back to the wall switch, if there is vaults at the burner it is faulty .
May 27, 2017 | Frigidaire FEF339E Electric Range
Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Jul 10, 2010 | GE JBP65 Electric Kitchen Range
Oven not heating KitchenAid KERC506HWH3
This is probably the thermal shuttoff fuse. Usualy mounted in the back of the oven. Aftermarket fuses are resetable but the OEM ones that come with the ovens usualy are not, so when they go out they stay out. This shuttoff only effects the power to the element so the rest of the oven appears to work.
The oven has to come out and remove the rear covers, behind the covers you will see 2 wires that go to a small 1/2 in dia "plug" that mounts directly to the surface with 2 screws.
Remove the connections and put a meter across the cuttout. it should read very close to zero ohms, if not its blown.
Apr 23, 2009 | Frigidaire FEB27T5D Electric Double Oven
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Oct 15, 2007 | Frigidaire FED300AS Electric Kitchen Range
Kitchen Ranges Logo
89 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
