Question about Maytag SkyBox MBV1976A Beverage Dispenser
(Overload and relay switch)
Hello.. I have a Maytag skybox model #MBV1976AAP I am looking for the relay switch that allows for the compressor to turn on and off. (Overload and relay) I can't find a part number. Maytag is not helpful either! thanks Louie (954) 816-2245
  • loulori21 Mar 10, 2009
    mike Thanks ALOT.. I feel inlove again now that I have cold beer just in time for baseball season by the pool...
    Louie
  • 90 Answers
Hey Louie -- I had the same problem -- maytag is a waste of help unless it still is in warrant
you need to replace the overload relay --- the kit cost $26.00
go to appliancezone.com
part # 4387835
email me with any more questions
Posted on Dec 30, 2008
My Matag Skybox compressor will not turn on. I can here it clicking and trying to come on.
HI. This is a strong indication of starter/overload relay failure. This clicking noise is coming directly fromm the relay device. it is damaged. this relay is the main starter of the compressor unit. It receives a signal from the main PCB. Once the power signal is received, the relay will regulate the starting, and stopping of the compressor, via control board and thermostat assembly. The failed relay will need to be replaced, asap. Once replaced, the unit will operate correctly. The relay is mounted on the side of the compressor. Once the bracket, and terminal wires are removed, you can gently pull it away form the compressor, to check the contacts and connections for corrosion. If any of the contacts or terminal connections are worn, replace them. Worn contacts, or corroded connections will not allow for proper current flow.
NOTE_ I would advise to locate the clicking. Make sure its coming form the compressor/relay location. There are some units of this nature out there that are fixed(compressor and relay intergraion). If this is the case, simply replace the entire compressor unit. If the clickiong is coming from the main control board(PCB), the PCB, will be the culprit.
Dec 01, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from skybox
Maytag never offered a replacement compressor for the SkyBox units. It was not a cost effective repar to make. If you are sure the thermostat is supplying 120VAC to the compressor, you can install a Supco URCO410 relay/capacitor/overload kit. This part should only be installed by a qualified service technician.
Feb 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox start relay is bad
you need to change the overload relay ---- there is a company called appliancezone.com
they sell the overload relay unit with all the parts for $26.00
email me back if you cant find it---- put in the model # for the skybox unit and you will see the item
item # 4387835
this is the problem -- if this relay goes bad the compressor will stay on and not supply cold air to the unit ----
Dec 16, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox by Maytag not cooling
our skybox just stopped cooling. i think the compressor kicks on but wont cool. can somebody please help me! thanks barbie
Jul 01, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
MBV1976AAP
Maytag did not offer any parts for the compressor on the SkyBox. Purchase a SUPCO URCO410 relay/overload/capacitor kit and install it per the instructions on the package.
May 02, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Dispenser Not Cooling
Sears.com is selling skybox parts. Go to appliance and parts and put in the model number of the skybox it is either mbv1976aab or mbv1976aap -- you can find this on the back of the skybox. It might have the part you need.
Apr 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox
I have a Sky box Model mbv1976aap series 10. It is complete but not working. I think it is the overload switch on the compressor as it arcs every time I plug it in. I don't want to fix it but I will sell parts for half price of parts direct website. I can be reached at scrapjunky@cox.net. I have dispensers, cooling fan, circuit boards, what do you need?
Mar 09, 2008 | Maytag MBV1976AAP Beverage Cooler
Look for a Service Information on a Maytag Skybox MBV1976AAP
I have a service manual, but you are screwed if you want to buy parts. They simply are not available
Feb 13, 2008 | Maytag MBV1976AAP Beverage Cooler
Maytag SkyBox MBV1976A Beverage Dispenser Logo
412 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
