Question about Kenmore Refrigerators
Kenmore side-by-side not ejecting ice
I have read some of the other threads and have shorted between holes H and T.  With the ice thawed, this shortcut WILL cause the motor to go through its full cycle.
Thought I had it made.  My thanks went out to the solution.  NOW - 6 hours later there is ice in the trough but none has rejected.  I again tried the shortcut but, alas and alack and sigh, the motor will NOT move.
Your thoughts will be appreciated before I replace the entire ice-maker assembly.  Thanks in advance.
fred
  • 2 more comments
  • fred594 Dec 03, 2008
    jopmcg
    First - a big thanks for the early response.
    The ejector blades went around when defrosted.
    The ejector blades didn't even budge when ice in trough.  Did NOT see motor even tried to turn.
    I have the temp control set at the "mfg suggested setting".  On the scale of 1 to 5 with 5 being coldest, I now have it set on 3.  Do you want me to turn it to 2 or 4?  (It was set on 2 before I "Fixed" it.  ;)
    fred
    temp about 7.  motor will still not turn when jumpering.  will not go on its own.  try frozen.  time for a new ice-maker unit???  I see where I can replace the entire unit for a few bucks more than just the motor unit.  ($96).  Whatcha think?
    fred
  • fred594 Dec 04, 2008
    106.55249400   s/n  SS1363205  purchased 4/2005
    fred
    Duluth, GA
    Being a private home owner, don't know if I could get wholesale :(
    Sniper:
  • 56 Answers
Did the ejector blades go around when you jumped it out? If they did not the the motor is probably gone and your going to have to replace the head of the ice maker or the whole ice maker. Check to see if home depot has a install kit for your brand. You'll probably pay less for the whole kit than the ice maker. But before you do turn the temperature down in the freezer.
Posted on Dec 02, 2008
  • 2 more comments
  • Joe McG Dec 03, 2008
    If you have a thermometer put it in to see the temp. We are looking for 8 degrees or lower. A good ice cream w/ high fat content like ben and jerry's will be hard at 00 if you don't have a thermometer. The other part that could be bad is the bi-metal sensor in the head of the ice maker. That is what you are bypassing when you put in the jumper. Standing by,
    Joe
    Fred what is your model number and serial number.
  • Joe McG Dec 04, 2008
    Wholesales for 75 for the complete kit new bin, water valve and icemaker around here could be 10 either way depending where you live. What city do you live in?
    Email me, I'll tell you how to pick it up at wholesale. didntwantemail@aol.com
The Refrigerator's ice maker makes ice, but will not eject the ice. Have tried to reset the ice maker but will not eject, any ideas?
The ice maker has heater that thaws the ice cubes a little before they are ejected. This keeps the from sticking to the form.
Jun 26, 2015 | Kenmore Refrigerators
Kenmore 56683501 side by side refrigerator not making ice
check the tubing for ice in the tubing at the back of the fridge.
If Ice, thaw it out by putting in hot water then reinstall it in fridge and make ice.
Feb 15, 2015 | Kenmore Refrigerators
Water not going to ice machine
We had this problem with our ice maker last week. We could get water through the door water dispenser but it stopped making ice.
We had read that the line could be frozen and that was the case.
We have a KitchenAid Superba and the easiest way to thaw it out was to remove the two screws holding the water hose elbow into the back of the freezer (pull the fridge out away from the wall to access it). It will come out with about a 5-6 inch long hard plastic tube which goes through the back freezer wall and joins with an aluminum tube (which may also be plugged with ice) that reaches the ice maker. Looking inside the tube we could see the ice blockage. Heating it up with a hair dryer made the ice plug drop right out. We had tried to thaw it out by heating the tube inside the freezer, but the ice plug was actually in the wall part of the freezer and we wouldn't have been able to thaw it out from the inside (short of shutting the refrigerator off). When the heat was applied...a 3 inch plug of ice dropped out of the tube, and there was even a very small piece of ice blocking the elbow part. We wouldn't have been able to thaw that area out without taking it apart.
Feb 16, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Kenmore elite side-by-side ice maker creaking!
Look behind the freezer rear trim panel for frosted/iced evap. coils and thaw if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer thawed, fridge warmed
The compressor is short cycling, or not starting. being purchaced in 2004, the compressor may be under a 5 year part and labor warranty with SEARS ...BUT GOOD LUCK!!!. Find ur receipt and warranty. read carefully and hold them to it.. empty it and unplug to be safe
Aug 25, 2009 | Kenmore Refrigerators
How do you thread a kenmore sewing machine I can't figure out how to thread the bobbin for kenmore machine 1385.15343600.  I am a beginner, so I will need pretty detailed instructions. Thanks! Jenny
Put the bobbin on the short metal stick on top of the machine. Unthread the machine. Put the spool of thread on the tall, left side stick on top of the machine. Take the thread and wrap it counter clockwise around the circular, short, metal thing on the left side of the top of the machine, only 180 degrees. Thread the thread through the hole in the bobbin (which should be on top). Press the bobbin to the right, into the little white thing. Pull the turning wheel on the right side of the machine out. While holding the end of the thread, softly press the presser foot so that the thread goes around the bobbin a few times. After that, cut the end down to the bobbin. Now, press the presser foot down and wind the bobbin until it stops on it's own.
Mar 05, 2009 | Kenmore 15343
ZIS480DRISS NO MAKING ICE CUBES
FINGERS THAT EJECT THE CUBES WAS JAMMED ON WHITE PLASTIC. REMOVED ICE MAKER THAWED CUBES IN THE TREY AND PRYED AWAY THE WHITE PLASTIC COVER. RE-INSTALLED
Jan 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator and Freezer not cooling....
  1. my kenmore side by side Model #465825 Refrigerator doesn't cool or and ice maker is'nt making ice.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side 22 ice maker
I'm assuming you're speaking of the mechanism that froze/transported the ice to the bin. Try a tiny bit of vegatable oil spray like Pam. If you are speaking about ice in the ice container, this is caused by a partial thaw of the ice...you're opening the door too often.
Aug 07, 2007 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
118 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
