Question about HP L1740 LCD Monitor
How do I get the built-in speakers to work
I have a HP1740 flat screen monitor that as far as I know has built-in speakers.
How do i get the speakers to work
  • Marcelo Antelo May 11, 2010
    According to the manual from the HP site, the L1740 does not have built in speakers. Do you see any speakers on it?
  • 85 Answers
Are you absolutly sure that it has speakers? If you're absolutly sure it does, there should be a 3.5mm audio in jack on the back or bottom of the monitor. It will look somewhat like a headphone jack, just like the ones you see on ipods (same size), although it may be green. You need a cable with a 3.5mm jack on either end.
Posted on Dec 02, 2008
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Does ultrasharp's 1800fp monitors have built-in speakers?
No built in speakers. There is a sound bar that you can get the attaches to the bottom of the screen to add speaers to the unit but it is sold separately.
Sep 26, 2012 | Dell UltraSharp 1800FP 18.1" LCD Flat...
No sound from inbuilt speakers or is the speakers built in?None came in the box!
Hi:
Sorry to bring this up to you but your LG flat screen does not have built in speakers.
have a great day>
Sep 07, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
Built in speakers do not work
Have you connected them to the pc's sound card - it doesnt go through the video cable.
Apr 24, 2009 | Acer AL1717-BBMD 17" LCD Flat Panel...
Flat sceen monitors, no sound
did you hook up the sound cable to the computer? and is the sound not muted in the on screen display?
check and advise
Jan 20, 2009 | Acer AL1715 17" LCD Monitor
Speakers
Click on the speaker icon at the bottom of your display to see if you are MUTED.
Did you intall the drivers?
Plug into the LIME GREEN port on your computer.
Dec 31, 2008 | Mag Innovision InnoVision LT865s 18" Flat...
Want to have four speakers
Buy a mini stereo splitter from Radio Shack
Dec 31, 2008 | Compaq 17" Flat Screen CRT Monitor
Need to over-ride built-in speakers so desktop speakers work. Ever since I hooked up my Compac W17q monitor, the built-in speakers have taken over, but I want my desktop speakers for sound instead. How can...
Assuming your using a Windows operating system, you need to got to the sound settings and set your computers soundcard as the preferred output device. (Its under Control Panel > Sounds and Audio Devices in XP)
Aug 26, 2008 | Compaq 17" Flat Screen CRT Monitor
We discovered the model we received did not have speakers. We are exchanging it for the same model that does. Thank you for your quick response! **** Winey
Apr 29, 2008 | Mag Innovision InnoVision LT865s 18" Flat...
No sound coming from speakers.
Did you run the audio cable from the computer to the monitor. If not you must have that for the speakers to work. If yes can you verify computer output with another pair of speakers to narrow it down to computer or monitor. If it is the monitor built in speakers that are the problem reply and we can go through a procedure to get them working.
Jan 18, 2008 | Cornea CT 1700 17" Flat Panel LCD Monitor
HP L1740 LCD Monitor Logo
173 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
