Question about Bosch WFL 2063 Front Load Washer
My machine fuses the whole house
My Bosch WFF1201 trips the fusebox for the whole house when it gets to the point where the water should start going in. Help
  • Anonymous Nov 14, 2007
    My machine fuses th whole house when it starts to drain the water
    Problem Solver:
  • 13 Answers
Water leaking onto the main motor appliance doctor
Posted on Feb 02, 2007
Bosch WFF2000 machine selected 60deg wash ,it clicks from main wash position on dial a couple of clicks then trips the whole house.This issue happened very suddenly.What could it be
agitator motor has broken windings causing a short when it tries to start. This trips the breaker in the main panel. If not repaired you could have a fire and that is why the breaker blows
Jul 23, 2016 | Bosch Washing Machines
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
My ewf1073 stopped suddenly while washing halfway. The cld is blank too. Check fuse and it is ok. Please help.
check whether the machine wall plug fuse and the house fusebox has blown/tripped
Jun 08, 2015 | Washing Machines
Bosch SRS53C02GB/27 tripped circuit fuse, Changed plug fuse still no sign of life
Has the circuit breaker / fuse in the meter box tripped or blown as well? If the machine tripped or blew a fuse, it is common for the heater element to be the cause or you have a water leak internally and its shorted something.
Mar 01, 2015 | Bosch Dishwashers
Bosch classic xx 5 mintues into the wash, stops and tripps elec.
Hello Sir,
I think that this is due to a faulty Main box Fuse. This usually happens when the heating elements of the washer go on. Try to inspect for faults, cracks or breakages in fuse box or in switches.
Thank you Sir,
Have a nice day.
Jan 13, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Baumatic bdw45.1 integrated dishwasher
sorry i have no knowledge of this "baumatic" product line. please repost with another expert
Jan 28, 2009 | Baumatic 18 in. BHD45 Slim-Line Built-in...
Bosch WFF1201 Washing Machine, wont drain
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
Jan 26, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My hotpoint aquaruis fdw60 won't power on. when I try this I get a flash on the power button and it trips my house contact breaker. i have checked the fuse, used another power point
you have a short in your circuit in the machine.
Check the whole machine for wire damage or leakage of water.
Or pump is burned through wich also can result in short.
please check all
May 03, 2008 | Dishwashers
Bosch WFF1201
Your problem is most likely the door interlock switch which is shorted. Replace the lock by removing the retainer spring around the door boot from the front, then remove door boot on side where lock is and fold back. Remove the two screws holding the lock (some models just clip off) and disconnect plug....make sure power is disconnected. A burning smell on the lock is usually a sure sign of failure, sometimes no indication at all.
Feb 01, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2063 Front Load Washer Logo
177 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
