Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch WFF1201 My machine isn't listed so thought I'd try this one. I have a Bosch WFF1201. When I press the on button it will click a couple of times to move on to the point where the water should start feeding in then it blows the fuse box for the whole house! Help. I was told it might be the relay. What's that and can I fix it? Or do I need to get a man in? Or should I just get a new one?
  • 27 Answers
Your problem is most likely the door interlock switch which is shorted. Replace the lock by removing the retainer spring around the door boot from the front, then remove door boot on side where lock is and fold back. Remove the two screws holding the lock (some models just clip off) and disconnect plug....make sure power is disconnected. A burning smell on the lock is usually a sure sign of failure, sometimes no indication at all.
Posted on Jun 26, 2007
2 Suggested Answers
  • 13 Answers
SOURCE: My machine fuses the whole house
water leaking onto the main motor appliance doctor
Posted on Feb 02, 2007
Polaris won't stop spinning/display screen black
TRY TO USE DIFFERENT PROGRAMM, BECAUSE SOMETIMES THE PROGRAMM GET STUCK ON ONE.
Jan 20, 2014 | Miele Washing Machines
Bosch wfd 1060
Sounds like the door lock, before getting a new one check it's not just the connection come adrift. Isolate from mains, open door, remove retaining spring from around door gasket and you can access the door lock (usually held in position by two Torx20 screws.
May 23, 2013 | Bosch Washing Machines
At start up the machine goes directly to CLEAN after about 2 minutes
Step 1:
Have the same problem with my dishwasher Bosch SHE4AM12UC. Bosch authorized repaiman has been out 3 times and changed main power board module 3 times, on the manufactures recommendation--he's given up fixing it and Bosch won't help either, just tells me to call somebody else on their list and get a second opinion (of course at my expense for labor). Anyway, steps are listed below that have worked for me to keep it limping along until I can get this figured out hoe to fix it.
Step 2:
When you start machine listen for drain pump to start up. Open door and you will hear sucking noise if it is running drain pump.
Step 3:
While you have door open, hold in start button and close door (this may take several times doing this) . Listen for the water to start to fill and wash pump will start (you will hear water spraying around from was arms). Machine will start and run normal cycle once this happens. If you don't hear this within a couple of seconds of procedure above, repeat the sequence until it works. Remember i said it may take 2-3 times to make it go.
Step 4:
Hope this helps. I'll keep trying to figure this out and come up with a solution. Forget trying to get anything done from Bosch or their "authorized" repair people as neither of them have a clue on how to solve the problem.
Jan 27, 2013 | Bosch Dishwashers
How do you shut off the annoying Bosch Nexxt 500 Dryer wrinkle guard?
Click HERE to get the Users Manual for your machine, from what I can see, it's in the selection option of the machine.
From the manual:
Select the option to be changed with the "Menu" button. Press the button to move to the next option on the display. The active symbol starts flashing.
The current active option setting is displayed on the right. These settings can now be changed with the "Select" button. Press the button to jump to the next possible setting. Pressing the "Menu" button again saves the setting. If you don't press any buttons for 10 seconds the settings are saved automatically.
Hope this answers your question. Please rate and comment. Thank You
Joe
Sep 01, 2011 | Bosch Nexxt 500 Plus Dryer
Bosch Classixx 6 1200 express has an error code F21 what is it
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
Mar 10, 2010 | Bosch Classixx WFO 2866 Front Load Washer
Bosch WFF1201 Washing Machine, wont drain
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
Jan 26, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFF1201
At the bottom of the machine on the front, there is a plastic cover (remove by turning the plastic screws a quarter turn anti-clockwise and pull off cover). The filter is behind this cover on the left hand side. It is unscrewed by hand anti-clockwise. Tucked into the plastic cover, you should also find the spanner to adjust the feet on the washing machine. good luck and rate me....
Feb 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
"water pipe empty" icon will not disappear from display screen 3, cannot brew coffee, first use - second machine to have this problem
I have a Siemens surpresso S40 with the same problem.
Try to fill the tank with hot water. I dont't know why but it solved the problem for me.
Jul 11, 2007 | Bosch Benvenuto B20 Espresso & Coffee...
Feb 01, 2007 | Bosch WFL 2063 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
334 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
