Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Our dishwasher is not running through all cylcles
Our Frigidaire Gallery Professional water seems to be heating ok. It does not seem to be circulating properly - it will not dissolve any type of detergent.
For what it's worth, the cycles are running much more noisily than they used to, and the cleans are not getting clean from what we are assuming a problem with a lack of spraying.
Thanks
Karen Dyer
  • regan hall
    regan hall May 11, 2010
    May seem like a stupid ? but are you sure the water valve is turned on?
  • 375 Answers
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Posted on Sep 11, 2010
Circulation pump not running
Hi Dok, thank you for your post!
I'm not sure what you are referring to as the circulation pump; however your Frigidaire dishwasher, FPHD2491KF, does have a drain pump. Therefore, if your dishwasher is water left in sump, then more than likely it would need replacing. Is your dishwasher making a grinding noise? If so, then it would be advisable to connect with a professional to accurately diagnose the drain motor. You can locate a certified technician directly through the manufacturer website or in your local directory to determine what may be causing the issue at hand.
Best regards!
Nov 23, 2013 | Frigidaire FPHD2491KF Dishwasher
Doesnt seem like water is heating and element not getting hot
Sounds like you checked the basics. Do you have hard water? Our element got covered with calcium over time and didn't heat efficiently anymore. I was able to chip some off, then ran the dishwasher with LemiShine a few times. The element worked much better after that.
Dec 17, 2012 | Frigidaire Professional Series 24 in....
Frigidaire dishwasher is not spraying water from bottom
From what you have described, sounds like the sprayer arms are possibly loose or being held into place and can't rotate, by dishware.
Aug 07, 2012 | Electrolux Frigidaire Professional Series...
Frigidaire dishwasher noticeably louder - circulation motor?
Try to position the machine, so that you can run the cycle and watch the dish washer. Remove the back panel and hear the sound of origination. Take suitable action as per your convenience. You can clean & replace the bearings if they are worn or replace as a whole unit.
Jul 06, 2010 | Frigidaire Dishwashers
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Disherwasher seems to run ok but dishes do not come clean and it leaves a soapy resdiue on dishes
You may have a problem with your heating element...if the water isn't staying hot the dishwasher will not work well...
Check out this tip and the there are others at the bottom of that one...
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
heatman101
Apr 19, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire gallery prof series dishwasher- arms dont work
Call a certified repair company as it sounds like the sump is clogged for some reason.
Jan 29, 2010 | Dishwashers
HO message flashing
My service guy told me this was due to the water coming into the dishwasher not being hot enough. He suggested I run the hot water in my kitchen sink prior to running the dishwasher. That seemed to resolve my issue.
Dec 28, 2009 | Electrolux Frigidaire Professional Series...
The top washer arm on a Frigidaire-Gallery Series falls off
This also happens with my GLD2350RC, except my dishes won't get clean. I believe its because the water does not circulate right inside. Also I have melted spots from where the arm rested on the heat element. I need to get this this back on.......
Nov 27, 2008 | Frigidaire 24 in. GLD2350RC Energy...
Frigidaire 24" fdb641rj dishwasher
the check-ball runs the top spray arm both arms don't run at the same time and that's the correct fill for this model whats your problem
Feb 07, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
228 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
