Question about Canon PIXMA iP90 Mobile Printer
It seems I have a clogged nozzle
HOWEVER: it wasn't so bad. Then I started cleaning and deep cleaning the printer using the prompts on my control panel. I even changed the printing cartridges TWICE thinking I had bad ink cartridges.
The printing is not getting better the more I clean, the problem is getting only worse. By worse I mean less than 50%--I'd say only 20%--of the page prints, and by that I mean it prints in wide streaks of white (gaps) and only thin lines of ink.
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I turned the printer on and off and it self-corrected.
Posted on Dec 03, 2008
My canon iP3500: Black print comes out patchily, despite many attempts at deep cleaning, Each time I deep clean, a couple of pages come out with the black print OK, then it goes patchy again.
It sounds to me like your cartridge nozzles are clogged. That's more common with recycled or refilled cartridges, but it can also happen with new cartridges if they are older. If you just purchased the cartridge you could try to return it. Otherwise, I would try to continue deep cleaning and nozzle checks until it starts to print. It takes a lot of ink, but sometimes that's the only way to get it to print. Usually it will work eventually. Do a nozzle check in between each cleaning and deep cleaning.
Feb 06, 2011 | Canon PIXMA iP3500 Printer
Have Pixma MP760. Problem with magenta print nozzle, which is not functioning properly. All others functioning fine. Repeated cleaning has improved the print colour but still patchy on the nozzle check...
Are you using aftermarket/refilled cartridges? To do a complete cleaning of the nozzle, you need to use a new OEM ink cartridge. Run the deep cleaning at least 3 times. This will clear the nozzle. You will eventually have the same problem with the other nozzles as long as you continue to use aftermarket/refilled cartridges. The inks used in them are not as highly quality controlled as the OEM inks so you will end up with clogged or partially clogged nozzles. The new OEM cartridges method usually clears the problem.
Let me know if this clears the problem. Thanks.
Mar 19, 2010 | Canon Office Equipment & Supplies
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
Nozzle for large (#5) ink is clogged and repeated deep cleaning does not unclog. How can I get the nozzle clean? I'm not sure how to reach the nozzle... Thought I could maybe wipe it off with alcohol. Any...
Remove the cartridge. Take a paper towel and dampen it. Place the towel in the microwave and get it really hot. Draw the cartridge head over it 7 to 10 times until ink starts to flow. Now, take a dry paper towel and draw the head over it the same amount of times to make sure it is dry.
Oct 27, 2009 | Canon Pixma MP500 All-In-One InkJet...
Photos printed come out faint and lines andblack streaks across the photos how do i solve this/
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Print quality can be improved by performing print head cleanings or print head deep cleanings. aution: Only used the approved methods below to clean the print head. Use of other methods may further clog the nozzles on the print head and may cause permanent damage the print head.
Note: It is important to check the cleaning results by printing Nozzle Check Pattern after each cleaning. Cleaning and Deep Cleaning consumes a certain amount of ink. Only perform a cleanings when necessary.
Print a Nozzle Check Pattern
  1. Confirm that the printer is connected to the computer and the printer is turned on.
  2. Complete or cancel any print jobs in progress.
  3. Open the Printers folder.
  4. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  5. Insert a piece of letter-sized plain paper in the paper tray.
  6. Verify the desired paper source for the Nozzle Check is selected on the unit by changing the Paper Feed Switch if necessary.
  7. Select 'Nozzle Check'.
Aug 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Can you help? After changing the cartridges, I keep getting a message about the ink head being incorrect...I am directed to press 'OK' which does not help; then to turn printer off and on again, which...
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning). Note:
  1. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
  2. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
Overview:
Step1:
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
downicon.gif If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
downicon.gif Print the Nozzle Check Pattern again.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
  1. Ensure that the printer is powered on.
  2. Press the <Menu> button.
  3. Press the left or right cursor to select [Maintenance/settings], then press <OK>.
  4. Press the left or right cursor to select [Maintenance], then press <OK>.
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Hi, we have a problem with our Canon Pixma IP3000 printer. Looks like Cyan and Magenta nozzles are badly clogged (countless cleans and deep cleans did not make any difference). I would admit that it was...
I use an ultrasonic bath for clening badly clogged nozzles. You can also try soaking in warm water for 15 mins. If this doesn't help then you might have to get a new head.
Dec 02, 2008 | Canon Office Equipment & Supplies
Printer doesn't pring
Try cleaning the printheads
Performing the printhead cleaning procedure
  1. Power on your printer, press and hold the "RESUME" button until the printer light flashes once.Note: You can also clean the printhead by clicking the Cleaning button in the Maintenance tab of the printer properties dialog box in Windows; or clicking Cleaning pull-down menu in the Printer Utilities dialog box on a Macintosh computer. Choosing this option will allow you to select all nozzles, black or just the colour nozzles.
  2. Pressing Resume on the printer will clean all nozzles. When the printhead cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.3. Perform the Nozzle Check Pattern test again
  3. If the results are satisfactory, resume normal printing
  4. If the results are not satisfactory, you may need to execute a printhead deep cleaning.
Deep printhead cleaning from the operation panel
  1. To deep clean the printhead from the operation panel
  2. Press the Maintenance button.
  3. Press the Right Arrow button three times.
  4. Press the Print button. Printhead deep cleaning starts.
  5. When deep head cleaning ends, press the Maintenance button to exit.
Deep printhead cleaning in Windows
  1. Make sure the printer is turned on.
  2. Click Start, then Settings, then Printers.
    Note:Windows XP users: Click Start, select Control Panel, then Printers and Other Hardware, then Printers and Faxes.
  3. Right-click the Canon S820D Bubble Jet printer icon, then select Properties.
  4. Click the Maintenance tab, then click the Cleaning or Deep Cleaning button. The Maintenance tab and procedures may vary for Windows 2000 and Windows XP. Follow the instructions when prompted for those operating systems.
  5. For each message displayed, click OK. The BJ Status Monitor opens automatically and closes when the printhead cleaning is done. The POWER lamp on the printer flashes green during the cleaning process.
May 18, 2008 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
78 people viewed this question
old marine
old marine
