Question about Panasonic PT-47WX49 47" Rear Projection Television
PT-47WX49 - Pink wavy horizontal lines
I have been having this issue for about a year now. My only 'temporary' fix has been to switch my cable box setting back and forth from 480p to 1080i ...back and forth whenever the lines show up. Some days I can go all day with either setting and some days I may have to switch a few times. I know it is not my STB since I can get the same lines during DVD play which is using a component input just as the STB.I even changed out he STB just in case. I am assuming that the component inputs are failing somehow. What is odd is I thought maybe it might be a heat issue but I can turn the TV on after being off all night and have the pink wavy lines from the get go. Anyone know what might be happening?
  • Art Turo Feb 01, 2007
    So will this set everything back to default then?
    All my settings? Even convergence settings?
    Will the is basically set my TV back to default then? Even my convergence settings and all?
    Guess I better get down to writing all my settings down!
    President:
  • 1,284 Answers
Try doing a reset of the TV first. On Panasonics this is done with the TV on and then pressing on the POWER and ACTION (on the fron of the TV only) buttons at the same time until the screen blanks out or a diagnostic screen appears. Once you do this all custom functions (color,tint,channel memory) will be back to factory defaults.
Posted on Feb 01, 2007
Sony bravia internet tv has a pink horizontal band across the screen
If the line is Horizontal then you deffinantly have a cable issue, replace the cable and that should do it, if it continues the problem could be in the port itself, if using HDMI switch to VGA or composite to test this theory. please keep me posted.
Dec 27, 2013 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Panasonic pt-50lc13 small wavy lines
Look to see if it happens on the rear audio and video inputs--that will narrow down where the problem is.
Be aware this model was RECALLED and all original owners were supposed to have the set replaced a few years ago.
Also rule out the signal---if using a cable box connect the cable without it directly to the coax fitting---box can cause this---stranger things have happened.
May 27, 2012 | Panasonic Televison & Video
I have pink and green wavy lines. Most pronounced at the bottom of the screen.
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Panasonic PT-47WX49 47" Rear Projection...
My Panasonic rear projection TV color is off
hello it sound like convergance ic might be the trouble it's a big job to do yourself a lot of testing and a lot of desoldering and soldering get a quote from an engineer
regards
shaun
Jan 19, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Wavy dark lines
Are the lines fine diagional across the screen and are they black in color.
Jan 01, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Help problems with Panasonic PT-47WX49
Can you post a picture of what your screen looks like and I will try an assist you with the problem.
Aug 09, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasoic PT-47WX49E
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Horizontal lines on start up
I get the exact same issue, exepct now it never clears up. I have tried to find someone to come look at it but no one does "house calls" anymore and everyone I call makes it sound so easy to just toss this beast in a car and bring it in. One of the repair techs said the issue sounded like the board had been zapped by a lighting surge...but of course there was no way to be sure unless I brought the set in.
Apr 03, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Horizontal lines when I first turn on my Pansonic 51" PT-51HW41 Projection TV
It's probably failing capacitors, does it squeal while this is happening?
Jan 14, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
119 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
