Question about Pioneer DVR-640H DVD Recorder/HDD Recorder
USB access on pioneer dvr 550HX
How do you access the USB input on the DVD player? on pressing "select input" it just goes through the inputs at the back of the machine, not the front where the USB input is.
thanks so much
  • 76 Answers
SOURCE: how do i record from hd to dvd on my pioneer DVR
There is no way to transfer HD to a regular DVD with out a conveter that usually plugs in the back of your DVR. Hope this helps =)
Posted on Feb 25, 2008
  • 3 Answers
SOURCE: Pioneer DVD Recorder - can get picture but no sound
If you are using RCA cables, you need to hook up three cables (1) yellow video, (2) white - left audio, (3) red - right audio.
Posted on Aug 19, 2008
SOURCE: how to use the usb port on Pioneer DV-410V DVD Player
Dear friends in problem solving.
My husband actually solved this problem by writing in the browser: Manual for Pioneer DV-410V DVD player.
That was available online and there it said that not all formats was supported by the USB port, so we tried to load a movie on a pen drive, insert it in the player and it opened and we just clicked play, so it was actually an issue of having an incompatible video file on the pen drive that made it not open in the first place.
Hugs from Solvejg
Posted on Dec 09, 2008
SOURCE: pioneer dvd recorder dvr-530H
The EPG is the electronic program guide trying to download TV listings.
http://en.wikipedia.org/wiki/Electronic_program_guide
This is normal for this player. To disable this, you would need to turn off the TV guide function.
Posted on Mar 19, 2009
erik9
SOURCE: Unlock Pioneer DVR-531H
Seeing this question over a year late but.... My Pioneer dvr-531h locked-up twice (no buttons work) - so i unplugged it for 10-30 min's. Plugged it back in, gave it 5 min's to 'warm up', then pressed 'power'- gave it 5 min's again- then it was fine.
Anyone know how to make it stop 'grinding'??????????????
(the unit has the built-in hard drive, with this, I hear the constant grinding that you sometimes hear on a computer. It does this when the power is on or off. It is loud enough to drive you mad.
Posted on Aug 29, 2009
Cant find the input button.
You should look for the user manual for your device. It should provide guidance to controls and cables. That guide may be on the brand site where you would try to track it through the model number. It is usually helpful to post the device, brand and model number so that a volunteer may provide better feedback. That said, here is a bit of information that may help. The remote with your TV may have a menu button which permits you to access settings. There are a number of "cable" choices within those settings. One permits input from the DVD player. Another permits input from cable/DISH TV. One permits input through a special high quality cable HDMI. If you pick the wrong one, you do not have a picture. You select these by scrolling with the up and down arrows and hitting the OK button. Let's say you find the selection for the DVD. You have to remember that you have been changing settings on the TV. Your remote will not control your DVD player (or DVR) unless you have pressed the button on the remote that changes it to a remote for such. Those buttons are usually at the top. And even if you do, the remote may still not control the DVD/DVR unless it has been programmed for that brand/model of DVD/DVR player. And you have to do that through the settings button on the remote. That usually requires you have the manual that provides the codes for a long list of products. But you may be able to use physical buttons on the player meanwhile, after you have setup the TV to receive the signal from that device as mentioned at the beginning.
Oct 14, 2017 | Televison & Video
I have a Toshiba D-VR16. How do I copy a VHS video onto a CD?
Just put the tape and a blank cd in and just press the Copy from the case.
Aug 10, 2010 | Toshiba Televison & Video
I want to record a film off my camcorder directly on to the hard drive of my Panasonic DVR-645H-S DVD recorder. I have put the input plugs at the front of the recorder from the camera but cannot get a...
You have to select the correct External Input, on TV, you do NOT use "Channels" Then select correct format either NTSC or PAL, turn on camera to play, then you should be OK.
Mar 07, 2010 | Pioneer DVR-645H-S DVD/HDD Recorder
Adding a dvd player to my dvr and older tv
leave coaxcil cable on dvr ;unplug the colored wires from the dvr output and plug them into the output of the recorder;plug a second set of colored wires into output of dvr and into input of recorder;be sure to set recorder input to proper setting on recorder (input one or two) now you should be able to record what your dvr plays or just use it as a dvd player ; you will need to have all three on to watch tv though.
Mar 01, 2009 | Cyberhome DVD Recorder - DVR1600
No signal
how do i connect a usb stick for a ch usb dvr to a video player
Jan 29, 2009 | Cyberhome DVR 1600 DVD Recorder
I am trying to record from my dvr to my magnavox 10d6 recorder
Connect the yellow/red/white out from the VCR to the same inputs on the 2160. Press setup. select general. select video select video input. select L1 or L2. press ok. select video or s-video.
press setup to exit.
select HDD or DVD (whichever you want to record to)
use source or channel to select L1 or L2
press rec mode to select sp/lp/ep/etc
press record to start recording
start playback on the input device
press stop to stop recording.
The manual is available as a PDF file on the web. It would save a lot of typing...
tom
Jan 20, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
How do i record from hd to dvd on my pioneer DVR
Feb 25, 2008 | Televison & Video
Pioneer DVR-520H DVD Recorder Picture is Yellow
If running component or RGB try replacement lead set. Otherwise is TV issue.
Oct 12, 2007 | Pioneer DVR-520H DVD Recorder
Pioneer DVR-640H DVD Recorder/HDD Recorder Logo
266 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
