Question about Compaq Presario R3000 Notebook
My Cd-Player doesn't respond to "THE PRINT SHOP DELUXE"disks
When I pull up a picture in my Print Shop and the computer asked me to put the corresponding Art-Disk in, it just flickers for in instant and nothing happens. In other appications the CD-DVD-player doesn't work right either.
Windows shuts down The Print Shop 3.0 Deluxe
print shop 3.0 is compatible with XP SP3 vista SP2 and windows 7. to install it correctly you must be logged in as administrator or right click the installation setup and choose Run As Administrator. if you dont do that it doesnt install correctly if you are trying to use it on any other windows system it wont work. print shop 4.0 is compatible with W8 or W10. once installed you may also have to Open the program using Run As Administrator too.
Sep 27, 2017 | Encore Computers & Internet
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
May 14, 2011 | Encore The Print Shop 23 Deluxe Full...
How do I access the clip art on the Art disc? I have windows 7 and Print shop 23.1 deluxe? I put the Art disc in the drive, when I look in the art gallery there is nothing there, even when I tell it to go...
try opening up the disk seperatly to the program & looking for the picture you wont then copy and paset it in but you shald find it under the menu bar in insert/ picture
Feb 19, 2011 | Encore The Print Shop 23 Deluxe Full...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Just got a new windows 7 and wanted to use my Print Shop 22 Deluxe but says certain parts are not compatible. What do I do?
just got a new computer with windows 7 and wanted to use my Print Shop 22 deluxe but says certain parts are not compatible , What do I do ?
May 20, 2010 | Broderbund The Print Shop 22 Deluxe Full...
Can you run print shop 20 deluxe from an LUA Account?
yes it is but before continuing to install print shop by other account make sure that your account is not limited access to install...
Jul 17, 2009 | Dell The Print Shop 20 Deluxe for PC
Can not get Print Shop 23 deluxe to install with Vista
During installation you must explicity tell the installer to install the Art Content. Had the same problem. Reinstall 1st CD and then choose modify and then choose all Art content.
Jun 10, 2009 | Microsoft Windows? Vista Home Premium...
Compaq Presario R3000 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
