Question about Frigidaire FEF336BC Electric Kitchen Range
Stove won't heat
Frigidaire electric stove model fef336ece won't heat, when I push the bake button it blinks and makes a clicking noise.
  • krisfr Dec 19, 2008
    same exact problem as you described! Any solution yet?
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Posted on Jan 02, 2009
Stove is clicking when I try to put the oven on and an ON light appears. Frigidair Galley Professional series
Posted on Dec 14, 2008
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I own FRIGIDAIRE ES100/105 (electric stove and oven). Yesterday I was using the oven and suddenly I heard a loud sound. I went to check it I found out the both the oven and stove were off. And not working....
HI. The actual issue will be with the main logic board, which is where the main element control relays are mounted. These very important relays are damaged. The main board will need to be replaced, asap.
With that said, if you could be so kind; Please post the entire model number so that i may pull up all necessary part numbers needed, as well as, service manual links and diagrams to help with your repair.
Dec 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
How do I replace glass top on the stove model number FEF336ECE frigidaire?
The following link explains step-by-step how to replace a glass cooktop on a kitchen range:
http://www.fixya.com/support/r4249512-replacing_glass_cook_top
If you have questions about any of these procedures, please post back and let me know. I hope this information is helpful to you.
Jun 18, 2010 | Frigidare FEF336EC Stainless Steel...
I have a 2 year old smoothtop GE stove. I was
that clicking usually means that the erc is trying to turn on the burners,
i would unplug the range
pull it out and check all the connections of the bake element
Oct 16, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Electric Range model FEF366EC - Oven disabled
You probably have a short that is causing the stove not to heat up or you not to be able to control temperature settings. The stoves are made only to last as long as the warranty, and when it expires, the stove all of a sudden wants to break down. You might have to get a whole new stove.
Jul 14, 2008 | Frigidaire FEF366EC 30" Freestanding...
Frigidaire FEF336BC Electric Kitchen Range Logo
2,461 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
