Question about HP Officejet Pro L7680 All-In-One Printer
Paper jam The jam is Mostly unjammed. But window says, "open print- carriage access door. I cant find how to open the print carriage access door.
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
Paper jam
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 07, 2010 | Office Equipment & Supplies
Errror e flashing. i cant see any paper jam or small object that affect the sensor.please help me
Nov 25, 2010 | Office Equipment & Supplies
Paper jam light on permanently, printer is jammed
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 25, 2010 | HP DeskJet 970cxi InkJet Printer
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
Nov 18, 2010 | Office Equipment & Supplies
Paper Jam {Printer does not detect paper
My printer isnt feeding paper in straight and it keeps on jamming and saying that there isnt any paper.. is there anything i can do to esay fix it???
Oct 25, 2010 | Office Equipment & Supplies
How do I re-set after a paper jam hp psc 1200?
Verify that the print cartridge door is closed.
The print carriage may be jammed, follow these steps to correct the problem:
1.
Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
2.
Disconnect the power cord from the all-in-one.
3.
Remove both print cartridges.
4.
Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
5.
Close the print cartridge access door.
6.
Plug the power cord back in.
7.
After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
8.
Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
If that doesn't work, maybe try this too:
Clearing paper jams
Paper jams can occur for a variety of reasons but are usually paper related. Follow the steps below to clear the paper jam:
1.
Turn off the all-in-one and unplug the power cord. With the power off, the paper feed rollers will turn.
2.
Open the rear access door of the all-in-one by pressing in on the left side of the access door and then pulling it toward you.
NOTE: All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems.
Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
If under warranty, contact HP to obtain a replacement part.
Click How to buy on this page to order replacement parts.
3.
From the rear access door opening, gently pull the jammed paper free.
4.
Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
Do not continue to push the paper in after some resistance is felt. If the paper is pushed in too far, more than one page will feed into the all-in-one at a time.
5.
Reattach the rear access door by inserting the two pins on the right of the door into the holes for them and then pressing in gently but firmly on the left side.
6.
Reconnect the power cord to the unit and turn the unit on. Source(s): http://www.castleink.com
Sep 01, 2010 | Computers & Internet
How do i clear a cartridge jam on my hp all in one printer
Is the paper feeding crooked and catching on the carriage? If so, remove the rear access door and clean the feed rollers with a damp cloth.
some other resion is The print carriage is the part that holds the print cartridges. Carriage blocked or jammed messages may occur for these reasons:
A paper jam was cleared from the front instead of the back on models that have a rear access door.
The print cartridges were installed incorrectly.
There is some obstruction in the path of the print carriage.
Open the print cartridge access door of the all-in-one so that the print carriage can be accessed.
Thanks,
Dec 03, 2009 | Computers & Internet
Paper Jam
Causes of repeated paper jams If paper jams occur repeatedly, one of the following may be causing them: The paper is being pushed in too far. The paper should only be pushed in until the first resistance. Continuing to push the paper in will force the paper up into the paper rollers and will cause the printer to pull in multiple pages. Obstructions in the paper path. Open the all-in-one (front and back) and check for obstructions.
  • Unlocked rear access door. Follow the steps above to install the rear access door correctly (see Figure 3). If this condition is present, the paper will skew in the all-in-one.
  • The paper guides are not positioned against the paper. Adjust the paper length and width guides so they fit snugly against the paper.
  • Incorrect paper. The paper should be flat and smooth with no folded, torn, or rough edges. Papers with a glossy finish and coated papers may not feed into the unit correctly. Paper that has already been printed on once can also cause problems.
  • Partially installed paper tray. The paper tray must be inserted all of the way into the all-in-one.
  • Dirty paper feed rollers. Over time paper fibers and dust will stick to the rollers and should be removed.. Also verify that the rollers on the rear access door are clean and turn freely.
Check Paper light flashes but there isn't a paper related problem The check paper light may also flash if there are other problems. Verify the following conditions:
  • Verify that the print cartridge door is closed.
  • The print carriage may be jammed, follow these steps to correct the problem:
    1. Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
    2. Disconnect the power cord from the all-in-one.
    3. Remove both print cartridges.
    4. Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
    5. Close the print cartridge access door.
    6. Plug the power cord back in.
    7. After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
    8. Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
  • Try to make a copy. If it pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism
May 21, 2008 | Office Equipment & Supplies
Paper jam?
  • Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
Nov 01, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP Officejet Pro L7680 All-In-One Printer Logo
115 people viewed this question
Seeker5211
Seeker5211
