The drill is ok but when forward or reverse is engaged the drill will start without you depressing the start button and will not stop untill the button is returned to the neuteral position.thanks
hi i will try help, well yes it will have adverse results on his gear box if he is putting it in drive and then reverse before the vehicle stops going forward, ile explain, when you engage the gear and drive forward, the centrifugal force is sent to the torque converter
This engages reverse gear within the transmission, giving the ability for the vehicle to drive backwards. In order for the driver to select reverse, they must come to a complete stop push the shift lock button in (or pull the shift lever forward in the case of a column shifter) and select reverse. Not coming to a complete stop can cause severe damage to the transmission. Many modern automatic transmissions have a safety mechanism in place, which does to some extent prevent (but does not completely avoid) inadvertently putting the car in reverse when the vehicle is moving forwards. This mechanism usually consists of a solenoid-controlled physical barrier on either side of the Reverse position, which is electronically engaged by a switch on the . Therefore, the brake pedal needs to be depressed in order to allow the selection of reverse. Some electronic transmissions prevent or delay engagement of reverse gear altogether while the car is moving. Some shifters with a shift button allow the driver to freely move the shifter from R to N or D, or simply moving the shifter to N or D without actually depressing the button. However, the driver cannot put back the shifter to R without depressing the shift button to prevent accidental shifting, especially at high speeds, which could damage the transmission.so hope that answers your question and end the feudlol, please vote thanks
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
In order to switch from hammer to non hammer on the 13624 there is a ring on the clutch near the chuck. The button on the side is for switching from forward to reverse. The part number you will need is 2601099112. This is something that happens quite often on these drills and you may consider getting two. They are less that 5 dollars each.
Take the drill out of the hammer drill setting when in reverse. Using the drill setting with the speed on 1 will give the power to free the bit. If the clutch will not engage, GENTLY but firmly switch between forward and reverse. This should work just fine. I hope this solution brings you success! Best Regards, Michael Mittelsdorf
The red button sits on a lever that changes the polarity of the switch output. If this lever feels loose and you can't feel it engaging anything then you need to split the housing and make sure it is seated properly. If it is, and the lever on the switch is moving fine aswell then you should check all the wires coming out of the switch, and if they are all connected properly you will prob need a new switch.
