Question about LaCie (301080) 60 GB Hard Drive
Change permissions for external Hard Drive on Mac OS X
I have a LaCie 60GB External Hard Drive that I can not get read/write permissions for. I dont have the computer that this permission was set on any more and cant seem to clear these settings. I have tried to format it on a PC and it removed all of the files but not this pesky permission problem. Can you please let me know if there is anything else I do to fix it??? Thanks
    President:
  • 2,961 Answers
You should be able to change the permissions, if you Right click on the drive and go to properties and click on the sharing tab and click permissions. apologies if you have already tried this.
Posted on Feb 01, 2007
File permissions on My Passport for mac
check the compatibility of the external hard drive. It might not support Mac. Probabely you external hard is in NTFS format and you need to reformat/re-partition it for using it in Mac OS.
Feb 04, 2014 | Western Digital Computers & Internet
External hard drive read only on my mac?
That's a very strange occurrence, I agree with you. The good news is that one of the standard administrative applications included with Mac OS X will doubtless fix what's happened on your disk, which is that a folder permission has somehow been messed up.
The program you need is Disk Utility and you can find it in Applications --> Utilities --> Disk Utility. Then simply select the drive you want to fix:
May 30, 2010 | LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB...
Trying to drag all files from itunes into lacie 250 g design by porsche hard drive and it won't let me.
Thank you for asking your question with FixYa Support.
I am not sure what type of computer you have that your LaCie is connected to, but first and foremost, make sure the external hard drive has been properly formatted to work with the operating system your computer has.
For Windows computers: the LaCie should be formatted in either FAT32 or NTFS (recommended- more secure).
How to Format a HD in Windows Vista
For Mac computers: the LaCie should be formatted in Mac OS Extended (Journaled) format.
How to format an external hard drive in Mac OS X
If your LaCie is already formatted, then the best way to import your entire iTunes library from the internal hard drive of your computer into the LaCie, especially if you are unable to drag and drop the library into you LaCie, is to try a simple copy and pasting of the ENTIRE iTunes folder from its home on your computer to the LaCie hard drive.
You can also use the website I like to reference which provides some good alternatives to effectively migrating your iTunes Library from a PC or Mac to your external hard drive:
Here is that support link:
How to Transfer iTunes Library to another Computer
(also included in this article, are external hard drives)
For sake of space, I want you to review this article, because I not only agree with its content, it is exactly what I would explain to you as well in a more condensed, easy to follow fashion.
I hope I have helped guide you well on your question.
Regards,
-Mactechtrainer
Mar 28, 2010 | Computers & Internet
Mac not allwoing write permission to an external hard drive
As long as the Esternal is formatted correctly it should work fine, it might be that you computer wont read the hard-drive, not the files.
Jun 16, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech usb drive model 96300-40001-001 Mac OS9 compatibility
If its 9.2 it may be because your mac is usb 1 and your external HDD is usb 2. It will recognize it but sometimes it takes longer to see the drive.
Feb 12, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
No Write permission when attaching Simpletech external drive to Mac OS 10
simple just format it for PC first then it should work for both
if you format it for MAC first it will not work on the PC
simple
PC are horrible for accessing files
mac's are more user friendly
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jul 02, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computer no longer reads drive
It sounds like a permissions issue, allways repair permissions after an update and dont use the machine while installing updates. If it will not repair permissions from disc utility then boot from the install disc, select language and on the page that appears there is a menu bar at the top, select utilities and disc utility and use that.
Apr 03, 2008 | Toshiba 200GB USB 2.0 Portable External...
Locked Folders
One week ago my LaCie external disk has been locked during a system reinstallation process in which the hard drive was plugged in.  The message was that I had no permission to access it. I thought I would loose for ever all the files I have been backed up for years. But finally I have got the solution for that. There is a sofware called MacPilot (I used version 3.2.6, $20, 15-day trial) that fixes it. Once instaled, click TOOLS, then "Files&Folders" at left, then "Unlock File or Folder", press "Choose", it opens FINDER and then you click LacCie Disk. When the padlock symbol at the botton of LACie disapears, you can finally change the permissions to "read&Record". That's all, and I hope it helps.
I recommend that you always unplug external hard drivers during system reinstallation to prevent that.
Feb 22, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
Cannot open hard drive
have you had this drive long if new then go to the control pannel on the mac and find the Amiistrative Tools open then computer managment open then Disk Mangement then open and find the unallcated drive then properties then partition format partition then go to nxt step then follow till end excepting all defaults as hdd is formated for pc not mac so id is needed to be reconised on mac. close all windows then in my computer you should now see hard drive letter if not turn off drive then return on.
Jun 15, 2007 | LaCie USB 2.0 Mobile 60GB 5400rpm 480Mbps...
LaCie (301080) 60 GB Hard Drive Logo
5,009 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
