Question about Dryers
Inglis apartment size dryer. 110 volts model x098003
Just bought this used. There is heat and it tumbles but it takes hours to dry a load?? The lint trap is clean and I just don't know what to do.
Help me if you can?
Thanks Jeannie
  • 121 Answers
The vent or the blower sounds like on is blocked is there any air blowing out the back with to vent disconnected it should be very strong there if not then you will need to clean out the blower housing it is in the back left side but i will tell you those 110 dryers are slow to dry
Posted on Dec 02, 2008
My dryer takes almost 3 hours to dry a average size load, when I bought it new it took around 1 hour to do a load. Im thinking it might be a heating element but how can I be for certain that is it without...
If you have an ohmmeter you can check it , check across the element connections. Have you cleaned the vents? If the air can't get out it could cause a problem . Also is the fan working ? Lint or something may be blocking it so it can't turn or slowing it down. You might check to be sure you have 220 volts to the dryer one side might be out and only have 110 volts. If you are getting some heat the element is not completly out. One other thing check with ohm meter from heating element connections to the heater box it may be grounded which might give you 110 volts. Hope this helps.
Dec 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
It takes 3 hours to dry a load of laundry
if this a 110 volt model, that is probably how long it takes. If this is a 220 volt model, you are not getting air flow. a plugged lint filter. a dryer sheet stuck to the back of the inside of the drum. your vent pipe going outside is plugged or the dryer vent cap outside is not opening and closing normally due to an obstruction.
Oct 10, 2009 | GE Spacemaker DSKS433EB Electric Dryer
Kenmore 600 dryer tumbling & heating, but not drying
Several reasonings. Step One make certain that you have 220 volts coming to your outlet. It takes 110 for the motor, and it takes 110 for the heating elements. If you have a volt meter that would be the best way to do that. Take the red and stick it in to the long part, and the black lead to the ground. Fuse houses was bad about this. Step Two it could be the elements are kicking off too soon. That is usually a sign of almost blown element. Step Three the heat sensor for the element prematurely kicking off the element.
Aug 10, 2009 | Kenmore 600 7965 Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Whirlpool Slimtwin gas dryer does not get hot but does tumble
Most likely it is the heating element, Unplug it, take the back off and you can see if it is bad
Jul 17, 2017 | Whirlpool LGR7646E Dryer
Inglis Dryer
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Oct 13, 2007 | Kenmore 63942 Dryer
Dryers Logo
366 people viewed this question
Top Dryers Experts
