Question about Maytag Neptune FAV6800AW Top Load Washer
Clutch on maytag neptune
Need help with clutch replacement, how is yours working out now?
  • loucastro66 Feb 21, 2009
    We have our machine open and can't figure out how to get to the clutch.
    Either southernbrin's or nysdaniels please help!
    Lou
  • 335 Answers
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium and heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Posted on Dec 15, 2008
  • dh1200s
    dh1200s Feb 22, 2009
    Lou you need the Service manual to start, pull it from this URL
    http://www.fixya.com/support/r1655507-fo... _top_load
    I leaned the washer back to get a better reach angle and jacked up the tub a bit to get my hands in there. It is a tight work area but can be done. The bolt is I believe 3/8” I used a socket wrench and I believe you need to turn CCW to remove try CW if that dosen't work. Follow the instruction for the clutch removal page 46 and 47. Did you take dc/UC errors on your machine? See my post about inspecting spring and clutch bearings in hub I had no hard falure (spring or rusted bearings) just a re-lube and I been service since mid Dec. with 40+ loads of all size with no issues. Getting the clutch seated was a bit tricky for me but can be done. I did not use a lock washer or thread lock. I would just reassembly and if the clutch is properly seated on the shaft it will stay on as designed. Good Luck
  • dh1200s
    Let me try that URL again
    If it dosen't work go to Tips and Tricks on this forum.
Everything has been working great since the clutch was installed correctly.  Have run at least 50 loads without a problem.  I am keeping my fingers crossed.
Posted on Dec 03, 2008
The spin cycle sometimes it works sometimes it does't
Could be a clutch issue could be severe Outer Tub bearing drag.
If you want to DIY
Google this Neptune TL Washer FAV6800AWW
If you need help open a post in that repair forum and I will try help you through your issue.
Feb 15, 2011 | Maytag Neptune FAV6800AW Top Load Washer
0. We need a manual for Maytag Neptune TL. IT IS
f your machine is a FAV6800A or FAV9800A see if this post will help. Service manual link or located there. here it is just in case
Clutch Fix
Here it is just in case;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My neptune TL gets down to 11 minutes left in the cycle and the the error "dc" appears...what does that mean??
You have a Clutch malfunction with your FAV6800A or FAV9800A Here is my link for the repair/replacement for the Clutch in your machine Clutch Fix.
Let me know if I have any questions on what need to be done......Rich
Mar 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Dec 07, 2009 | Maytag Washing Machines
I Have a Neptune HE TL fav6800aww and it keeps giving me the DC error code which i understand is a balance code but i emptied the washer and ran it and still get the code?
hris,
The FAV9800AW the dc/UC errors are caused by a clutch malfunction.
Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
It is a tight work area but if you are handy you can get away with a re-lube of the One-Way rollre clutches in the clutch pully you could be working today. If you need to replace tthe clutch I recommend a $60 clutch. Call in a repair service and you are looking at around $300. I will help you thru the process.
Post back if you have questions or need help.
Rich
Oct 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Rich
Oct 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Clutch removal on Neptune TL
I checked with the person that was watching me remove the clutch and he said RH. Make sure you reseat the clutch properly on re-install. I had to place the belt back on and rock it back and forth to re-seat on the shaft. Without removing the tub, it's a tight work space. We did raise the tube a bit with a lever under the motor to get a bit more clearance.
Jan 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Replace the clutch.
Mar 10, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune FAV6800AW Top Load Washer Logo
268 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
