Question about Intuit QuickBooks: Pro 2005 for PC
Printer not compatible to quickbook forms
HP office jet J6400 prints information on form but not outline of the form will n ot print. This is a new printer.
I brought up the HP printer solution chat line and was assisted by a very capable person who assisted me locating the problem.
Thank you for your response.
Posted on Dec 03, 2008
Im trying to print an invoice from Quickbooks but i cant find a online printer
Open QuickBooks. Then go to File at the top left side of the page. Then scroll down to set up printer. Choose the form you wish to be able to print in QuickBooks and this will take you to a place to choose your default printer. Click the arrow next to the name of the printer it has stored as default and choose your printer (hp photosmart) and then close the window and this will save your choices. Repeat the same procedure for each form name you wish to print in QuickBooks.
Jun 23, 2010 | HP Photosmart C3180 All-In-One InkJet...
Tip
Solving printing problems in QuickBooks
If you are having problems printing in QuickBooks, follow these simple instructions to set up your printer correctly.
Open QuickBooks
Go to "File" at the top left side of your screen & click on it
This will open a drop down list
Choose "set up printer" & click on it
This will take you to a list of forms printed in QuickBooks
Choose the form you want to print & click on it
This will take you to a place to choose & set your default printer
Find the box that has the current default printer in it & look for the arrow
Click on the arrow next to the box with the printer name
This will give you a drop down list of printers to choose from
Find the name of your printer on that list and click on it
Then save your choices by hitting "ok" and closing the box
Repeat these instructions for each form you wish to print in QuickBooks.
on Sep 09, 2010 | Intuit QuickBooks: Premier Manufacturing &...
Printer suddenly stopped working with quickbooks but will still work with all other programs. window states: change port assignments or reinstall software. printer is hooked up wirelessly
  1. Open the QuickBooks sample company and try to print the same form or type of form. If it prints successfully, your company data, form template, or customized report may be damaged.
  2. Reopen your company file and try to print an uncustomized (standard/default) form template or non-memorized report. If the issue occurs again, refer to Verifying and rebuilding the QuickBooks company data and then attempt to print again.
  3. If you were printing a batch of forms in QuickBooks, attempt to print a single form. If successful, try printing smaller batches.
  4. If you were able to print from QuickBooks in the past from this company file:
  5. Turn off the printer, restart your computer, and then turn the printer back on.
  6. In QuickBooks, choose File > Printer Setup and check the printer settings for the specific form you're trying to print.
  7. Click Help in this area for more detailed instructions on these settings.
  8. Ensure that you have the latest printer drivers for your printer. Go to the manufacturer's website to download and install the most current drivers.
  9. Replace the QuickBooks Qbprint.qbp file:
  10. Close QuickBooks.
  11. Rename the qbprint.qbp file.
  12. Open QuickBooks and attempt to print again.
  13. If the issue persists, repair the QuickBooks installation.
Mar 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
Quickbooks forms will not print on newly installed HP 6500
I deleted the qbprint.qbp file and that fixed it for me. Aggravating regardless.
Feb 15, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I have XP and QuickBooks Pro 2007. QuickBooks PDF Converter shows up with my printers, but when I am in QuickBooks, and click on print, it is not an option. I have removed and re-installed the converter...
You want to print things while in QuickBooks right? That's your problem? If so, then open your QuickBooks file and go to "file" at the top left of the screen. Click on File and then choose "set up printer" from the drop down list of choices. This will open up a list of forms. Choose the form that you wish to be able to print. Then lick on the arrow next to the printers name that comes up as the default chosen in QuickBooks. Change the printer name to the printer that you want to use to print the form. Then choose "ok" and close the window. Repeat the same instructions for each form that you wish to print with your printer. You dont want to use the QuickBooks PDF converter as the choice of printer. It's not a printer driver.
Nov 09, 2009 | Intuit QuickBooks Pro 2007 Full Version...
HP Office Jet 630 will not print
please check whether the data cable rx232 which is used to connect the printer to pc is fine. try someone else's cable(e.g friend) and check whether it is able to print .re install the software that is provided along with the printer in the form og cd or dvd. hope your problem will be tackled then
May 25, 2009 | Office Equipment & Supplies
HP Officejet J6400-will not print after restart
you may need to purge stuck jobs. you do that by stopping then restarting spooler.exe. see running services ie right click my computer and choose manage. once you do that it should print. if it doesnt then its an IP address issue, print a status sheet, usually OFF then hold in button, keep holding and turn on printer it will print status sheet. check IP address is correct as per printer properties.
Dec 19, 2017 | HP Officejet J6410 All-in-one InkJet...
I can only print the 941 form in quickbooks. Nothing else.
Open QuickBooks and go to file at the top left of the screen. Click on it. This will give you a drop down list. Choose "printer set up". This will give you a list of forms. Choose the name of the form you want to be able to print while in QuickBooks and this will take you to an area to choose your default printer. Click the arrow next to the name of the printer you want to use to print your forms and then save and close the window.
May 05, 2009 | Intuit QuickBooks Premier Contractor 2008:...
My printer will not print.
When you get to the "Print" window, there should be the area where it says the type of printer. There is also a drop-down arrow. Click on the arrow and highlight your HP printer.
Jan 27, 2009 | Epson Stylus Pro 4800 Color Photo Printer...
Printing landscape instead of portrait
this article may explain how to change it
http://hints.macworld.com/article.php?story=20070613051850612
Mar 05, 2017 | HP OfficeJet 7410 All-In-One InkJet...
Intuit QuickBooks: Pro 2005 for PC Logo
94 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
