Question about Minolta Office Equipment & Supplies
Machine Trouble Call Service (17H) Konica Minolta Magicolor 2490 MF A gear moved while trying to change cartridge. Do I need local service? Atlanta GA area
  • Minolta Master
  • 6,674 Answers
Yes you do how did gear move.
Posted on Jan 24, 2016
  • 214 Answers
SOURCE: Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Posted on Dec 07, 2007
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
admin734
  • 268 Answers
SOURCE: I have a Konica/Minolta 2490
17H is an error for the toner , either they are not in all of the way or the latch is not closed....to fix it simply take out the toner and put them back in making sure the latch is closed all the way :-)
Posted on Oct 03, 2008
  • 118 Answers
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Posted on Nov 18, 2008
  • 97 Answers
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
The fuser temperature is too high. There is probably some residue from the transparency left on the thermister or the thermister went faulty that causes a wrong reading. The only solution would be to have the printer serviced.
Posted on Aug 05, 2009
Ow do i fix the error message MACHINE TROUBLE SERVICE CALL (0310) on my konica...
replace the print head. That's the part that houses the LASER. try this site for the part
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
if not try local Konica Minolta dealer
Sep 28, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Can the machine still fixable when it just flashes ERROR light and the note that says: CAUTION Machine trouble. Service call (102H). What do I need to do?
Telephone the nearest KONICA MINOLTA store, and ask for a service-call, i.e., a technician to come and fix your printer.
Oct 05, 2010 | Konica Minolta magicolor 2480 MF...
I have a Fatal Error Code: 17H Can you help? It is a Magicolor 2530 DL color printer.
Check your toner cartridges, one of them is seized up. Remove all cartridges and turn the gear on the right side backwards ( counterclockwise) about 10 times and see if it turns smoothly. I don't know why but 90% of the time its the cyan that gets stuck.
Jun 11, 2010 | Konica Minolta Magicolor 2530 DL Laser...
FATAL ERROR
your printer is laser printer change toner cartridge right,
you may try
1) Open the front door and remove the toner cartridge.
2) you will see a small round hole near the colour toner cartridge
3) hold a screwdriver in that hole and the carousel will rotate freely. 4) Move the carousel round and remove each one of three cartridges at a time.
set back all cartridge close door.
Jan 29, 2009 | Konica Minolta magicolor 2300DL Laser...
I have a Konica/Minolta 2490 copier that has a service code 17H what is this
Oct 03, 2008 | Minolta Office Equipment & Supplies
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta Magicolor Fatal Error
Remove each of your cartridges one at a time and see if you can spin the toner rollers by pushing on the little white plastic gears with your finger. They will be tight but you should be able to spin the roller by moving the little gears around.
My printer started giving the Fatal Error Code 17H and I did all the removal of the four color cartridges and re-seating each of them to no avail. After removing each cartridge and checking to see if I could rotate the toner roller I found that the yellow cartridge was extremely tight. I took the cartridge outside and used a can of compressed air to blow all the toner off the roller and tapped the cartridge on all corners and shook it back and forth several time. Finally I was able to get the toner roller so that it would rotate when pushing the little white gears like the other three cartridges.
After replacing the cartridge in the printer it worked with no more error codes. Hopefully this will fix the problem until I can order a new yellow cartridge.
Keith
Jan 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Errors
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
78 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
