Question about Mitsubishi VS-45607 45" Rear Projection Television
I am trying to remove the screen on my Mitsubishi VS-4561 rear projection tv to clean it, how do I remove it? I know it slides up, anyone have a manual???
    Novelist:
  • 100 Answers
For my VS-45607 I had to first take off the speaker grill. Then there is a panel just below the screen that can be removed with screws; I removed this just for wire clearance. Then there are a few screws that are along the bottom of the screen that you take off and you should be able to slide the screen up and off. Good luck.
Posted on Dec 05, 2008
How do i clean the projectors and screens of my mitsubishi vs-50607 tv
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Sep 19, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I don't know how to get to the mirror and projection guns
the front trim on the tv pops off...there are screws all the way around the screen that you have to take out to remove he screen to get to the tubes and the mirror. once you pop the trim off youll see how easy the rest of it is
Feb 21, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Cleanng the projection mirror
remove the speaker grill, you will see the screws holding the front screen, remove the screws and the connectors going to it and slide the screen up and off.
Sep 18, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TV problems
I have a mitsubishi HDTV 1080 Integrated and the speakers are off and I can't get it back on
May 14, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Apr 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs-50603 removing screen for cleaning
Don,
You were in the right place going at it from the front. After removing the grill the bottom edge of the screen has a series of screws holding the lower edging down. Remove the screws and gently but firmly work the sides of the screen frame up to unlatch the top. When you have the screen/frame in your hand just be careful not to go to far with it - wires attaching the panel controls are still attached and don't have a lot of extra length.
Clean the cans, mirror and reverse area of the lenticular screen and re-assemble.
Bill
Mar 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Cleaning lenses/lamps on mitsubishi VS-60805
A can of compressed air might do the trick. If dirt is stuch, I'd suggest useing the same chemicals/cloths/etc you would use for cleaning camera lenses. Check at your local photo store.
Just make sure the lenses aren't hot when you apply cold and/or flamable chemicals.
Nov 04, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
